deploying a FEX considerations
truetaurus
Hey
I have a few questions regarding deciding upon a FEX:
What type of architecture should be used? This would be ToR?
What are the clear benefits of it? Easier to manage?
What drawbacks are present?
Reza Sharifi
The Fex is usually used as TOR.  You also need a couple of 5Ks or 7Ks to connect the Fex to.
Leo Laohoo
The concept of a remote-end-line-card, aka FEX in Cisco's marketing parlance, is a significant (if not a major) hit.  It's so successful that this concept will make a re-incarnation very, very soon.
Depending on what you're hardware is, FEX requires a "mother" controller because the FEX is, literally, a dumb switch.  The mother controller acts a single management entity.  Controllers comes in various forms, the traditional one is the Nexus 5000/5500, Nexus 6000 (if you want to play with alot of 10 Gbps and a few 40 Gbps), and Nexus 7K.
Be aware, that use the Nexus 7K (to manage 2K), as a last resort.  Why?  It's is cheaper to buy more Nexus 5K/6K vs buying more 7K as you add more 2K.
You'll also see alot of documentations about dual-homing the Nexus 2K up to two Nexus 5K.  Please avoid that temptation.  Instead, the best "well proven" practice is to dual/multiple-home your uplink to a single Nexus 5K and dual home your servers to two Nexus 2K.
