VLAN Help with BYOD
jtbarnes1
I'm pretty sure I'm on the right track and somewhat close to a correct setup for this.  The goal is to get a wireless controler to route default (safe) traffic on vlan1 and all BYOD traffic (bad) on vlan2.  So far I have the controller tunneling the BYOD traffic back to the controller and tagged at vlan2.  All other SSID traffic which is internal and safe is vlan1.  My problem is with my current setup all the traffic still see's each other.
The goal is to keep VLAN2 seperate and unable to malware up all the internet network servers, while still providing internet access.
Internet access edge is 10.3.3.254 (ASA Firewall)
All internal traffic is 10.x.x.x (10.3.x.x 10.1.x.x 10.2.x.x etc)
BYOD is VLAN2 and 10.8.x.x 255.255.0.0
I'll post the parts of the config that matter.. and just as a show here is the overall IP route, but I won't go into detail on all the ranges, just know they are interal network (safe), except BYOD traffic.
Gateway of last resort is 10.3.3.254 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 10.3.3.254
      10.0.0.0/8 is variably subnetted, 8 subnets, 3 masks
D        10.1.0.0/16 [90/28672] via 10.3.3.2, 6w6d, Vlan1
D        10.2.0.0/16 [90/28928] via 10.3.3.2, 6w6d, Vlan1
C        10.3.0.0/16 is directly connected, Vlan1
L        10.3.3.1/32 is directly connected, Vlan1
C        10.8.0.0/16 is directly connected, Vlan2
L        10.8.1.1/32 is directly connected, Vlan2
C        10.102.0.0/24 is directly connected, GigabitEthernet1/0/7
L        10.102.0.1/32 is directly connected, GigabitEthernet1/0/7
      192.168.1.0/30 is subnetted, 2 subnets
D        192.168.1.4 [90/3328] via 10.3.3.2, 6w6d, Vlan1
D        192.168.1.8 [90/3072] via 10.3.3.2, 6w6d, Vlan1
IP routes
ip route 0.0.0.0 0.0.0.0 10.3.3.254
So here we can see I basically have two vlan's, vlan1 (default) and vlan2 (BYOD I've configured as 10.8.1.1).
interface Vlan1
ip address 10.3.3.1 255.255.0.0
interface Vlan2
ip address 10.8.1.1 255.255.0.0
Next is the show vlan print out.
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/1, Gi1/0/3, Gi1/0/4
                                                Gi1/0/9, Gi1/0/10, Gi1/0/11
                                                Gi1/0/12, Gi1/0/13, Gi1/0/14
                                                Gi1/0/15, Gi1/0/16, Gi1/0/17
                                                Gi1/0/18, Gi1/0/19, Gi1/0/20
                                                Gi1/0/21, Gi1/0/22, Gi1/0/23
                                                Gi1/0/24, Gi1/1/1, Gi1/1/2
                                                Gi1/1/3
2    VLAN0002                         active    Gi1/0/8
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
DHCP Setup, This is handing out 10.3.x.x addresses on the 10.3.x.x network and the BYOD is given 10.8.x.x.  There are excludes listed from this ranges just not posted here so this is setup correct.  I can currently get a 10.8.x.x ip over the wireless and connect to the internet so this dhcp is working correctly.
ip dhcp pool TES
   network 10.3.0.0 255.255.0.0
   dns-server 10.3.3.4
   default-router 10.3.3.1
   lease 7
ip dhcp pool BYOD
   network 10.8.0.0 255.255.0.0
   dns-server 8.8.8.8
   default-router 10.3.3.254
   lease 7
Next is eigrp to cover the bases.
router eigrp 1
network 10.3.0.0 0.0.255.255
network 10.102.0.0 0.0.0.255
redistribute connected
Next is a interface list of the useful stuff.
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
switchport mode trunk
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust dscp
macro description cisco-router
auto qos trust
spanning-tree portfast trunk
spanning-tree bpduguard enable
interface GigabitEthernet1/0/6
description Ruckus ZD3000
interface GigabitEthernet1/0/7
no switchport
ip address 10.102.0.1 255.255.255.0
interface GigabitEthernet1/0/8
switchport access vlan 2
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
So here we can see the interface list.  Ge1/0/1 connects to the ASA Firewall and it's IP is 10.3.3.254.  Ge1/0/6 is our Ruckus Wireless controller which is dropping the traffic on the network, both Vlan1, and Vlan2 tagged BYOD traffic.  Ge1/0/8 is setup as a access port purely to test vlan2 and make sure there was nothing on the wireless side of the controller effecting this.  Currently I can ping 10.8.1.1 from any laptop connected by the wireless.  However I can also ping 10.3.3.1 (this switch) and any other range of IP addresses on the internal network.
My Goal is to have vlan1 and vlan2 traffic connect to the wireless controller via Ge1/0/6 and also be able to access Ge1/0/8 which will be a future radius/auth server for this wifi.  Then have this traffic get internet via 10.3.3.254 or Ge1/0/1.  However I do not want any of the Vlan2 traffic to be able to talk to any of the other ports.  I'm not sure what is setup which is making this occur currently.
jtbarnes1
Ok I've figured out what the problem is.  Because this is a layer 3 switch and ip routing is enabled.  I have setup intervlan routing by assigning the ip address to vlan2.  I'm pretty sure this is what I would need to do anyhow since it must communicate with 10.3.3.254 the firewall.  Next I need to figure out how to keep vlan2 traffic coming from Ge1/0/6 from getting to any interface except Ge1/0/1.  Suggestions on the best way to do this?
