Design question, interconnecting two 9500 stacks
I am currently setting up a new network at my company and have a question about my design.  We have 2 buildings side by side with fiber between the buildings.  I bought 4 9500's for the core and have set up 2x2 as stackwise stacks for a collapsed core configuration.  My question is, originally, I thought I would do a layer 3 port channel between them and route traffic between buildings but now I'm not so sure.  I was reading about multichassis etherchannel and that seems like it might be the way to go.  There are not separate networks in each building, they use the same vlans.  I might change that in the future but for now, they will be the same.
Each building will have its own internet connectivity and be a backup for the other building and it just seemed logical to use routing but it seems that I can put both virtual domains in an etherchannel and that will serve the same purpose and be more efficient.  Recommendations?  Thanks!
NetworkEngineer00237,
The original diagram was correct with respect to FW to SWV connections. I just looked at it incorrectly.
The connection from SWV 1 to SWV 2 will be 4 links, either using ECMP or L3 Multi-Chassis EtherChannel.
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking and Cloud Group
8 Replies 8
balaji.bandi
Worth deploy 2 X stackwise virtual and make them different VLAN segment for their own internet segment.
make sure you have right license to deploy stackwise virtual, if no this require re-design.
BB
Thank you for the reply.  I have 2 of the switches in stackwise virtual domain 1 and 2 switches in virtual domain 2 so they are configured for stackwise virtual.  Are you saying I need to create a L3 transit vlan between the stacks and route between them?  If so, that was my initial design but it seems that with multichassis etherchannel between the stacks, I wouldn't need to do that.  Is that correct?
balaji.bandi
yes for the L3 traffic you like to exchange -
for your stack they stay respected SVL domain and using Transit link to go otehr side ?
make a smalll HLD diagram so you are clear with goals.
BB
Here is a diagram of how I want the new network to be.  The fiber between buildings is 10g om3 multimode I believe.  either way, L3 connectivity is not required.  I'm just not sure whether I should do L2 or L3 between and how I should configure it
If you are going to directly connect the two SWV , you should make sure they are cross-connected with 4 links. This is the Best Practice for connect two SWV domains. In your picture, you have just 2 connections between the two SWV domains. Whether you use L3 PortChannel or Equal Cost Multi-Path (ECMP) routing between the two domains is up to you.
Looking at your picture, you should also cross connect your WAN devices to each of the SWV members in a domain instead of connecting each WAN device with two connections to a single member of the SWV domain.
Every device that connects to a SWV domain should connect to each of the SWV domain members if possible.
Cheers,
Scott Hodgdon
Thanks for the reply Scott.  So you are saying I should have 2 ports on each switch in each SWV for uplinks to each other?  I will have to look and make sure I have enough fiber pairs.  I should, there should be 6 in the cable.
My diagram must not be clear, I will have 1 port from each switch to go to each firewall.  I tried to color code them so it would be easier to read haha.  I also plan to make those L3 port-channels for redundancy and routing.  I made a rudimentary drawing that may better illustrate what i'm trying to do
Cheers,
Scott Hodgdon
Ok, thank you for your advice, that's what I needed to know.  I have setup a L3 port-channel between the SWV's with routing via ospf and its working but i'm blowing it away and starting over.
