Designated switch
Hi all,
I am preparing for the CCNA exam and currently studying STP. I have a problem in understanding Designated switch and designated port concept. I have read several documents and books, but unfortunately none of them helped me to understand this feature.
Can anyone describe me this feature?
Reza
2 Accepted Solutions
rolf.fischer_2
Level 5
Level 5
do you know the STP flash-animation at http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00800951ac.shtml?
It's realy helpful for understanding STP.
Another great resource is http://iws.ccccd.edu/sbutler/courses.html.
Good luck for your exam!
Rolf
Jon Marshall
Hi Reza
Root ports on switches lead to the root bridge. Designated ports lead away from the root bridge. eg
You have 3 switches A B & C
A is the root bridge.
B has a root port of fa0/1 which is the connection to Switch A.
C has a root port of fa0/1 which is the connection to switch A.
B & C are connected to each other using ports fa0/2 on both ends.
So we have a loop in the network ie.
traffic sent from A to B will be forwarded onto C and forwarded onto A etc...
Now, one of the FA0/2 ports on switch B or C will be become the designated port for that network segment and be responsible for sending and receiving traffic on that segment. The other fa0/2 port will be placed in a blocking state.
So let assume that after the BPDU's have been transferred the fa0/2 interface on Switch B is chosen as the designated port.
Switch B is now the designated bridge for that lan segment as it has the designated port.
So fa0/2 on switch C is now put in blocking mode and you have effectively removed the layer 2 loop.
Hope this makes sense
Good luck with exam
Jon
rolf.fischer_2
Level 5
Level 5
Rolf
Jon Marshall
Hi Reza
Good luck with exam
Jon
