Bandwidth Restriction
jweldin
Community Member
I would like to restrict 192.168.1.x in a routed network from only getting 512 MB of Internet access while users on 192.168.6.x have full bandwidth access. Is there an easy way to do it? Both IP addresses are subinterfaces on my LAN side, and the WAN goes directly to the Internet
Amit Singh
You can use modular QOS configuration on the router to achieve the same.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800bd909.html#wp89799
HTH,Please rate if it does.
-amit singh
ferla
Community Member
use traffic-shape.
- create ACL
- configure traffic-shape in interfaces eth and serials.
Cleverson Ferla
