Destination Host Unreachable
I have an issue when I ping PC5 or PC4 from either PC6 or PC7. When I run in command prompt "ping 220.10.100.66" I get the destination host unreachable message. 220.10.100.66 is the IP for PC5. I have attached the pkt file in the form of zip file for assistance. Thank you.
Martin L
you have Auto-Summary enabled on both EIGRP by default with IOS 12.x version. Since IOS 15 or Name mode of EIGRP, Cisco has disabled auto summary (no auto-summary) by default (which you do not see under router eigrp mode).
it just happened that you have dragged older routers with 12.z version.   For CCNA exam please use IOS 15.x
show ip route tells you story; it shows packets are dropped because of auto-summary simply summarize routes to Null0.
D 200.100.100.0/24 is a summary, 00:01:15, Null0
Just add on at least one of routers (it should be on both)
router eigrp 1
no auto-summary
Regards, ML
**Please Rate All Helpful Responses **
Martin L
router eigrp 1
no auto-summary
Regards, ML
Thank you.
