08-03-2021 06:41 AM
I am trying to setup a SF350 as a simple switch with a DHCP server. I have the SF350 setup with one address pool. After initial setup, the DHCP server is running and responds to DHCP requests as expected. I save the configuration as a startup configuration. After a power cycle, the settings are correct, however the switch does not respond to DHCP requests. If I go and reapply the DHCP address pool setting, the DHCP server will start working again.
We have been using the SF300 in the past with no problems.
Any insights would be greatly appreciated.
Thank you
Solved! Go to Solution.
08-03-2021 01:41 PM
It is now working, I had to change the default IP address for the switch.
Now it is working as expected.
08-03-2021 07:03 AM - edited 08-03-2021 07:03 AM
Hello
Suggest you save the dhcp binding table so can be restored as/when the router is reloaded.
config t
ip dhcp database tftp://x.x.x.x/dhcpbinding
08-03-2021 10:52 AM
Hello Paul,
The network is a very small closed network with limited (5) IP addresses and a 1 minute lease. When the system is powered down, I do not want any bindings saved. I want to start fresh.
Thank you for your quick reply.
08-03-2021 01:41 PM
