Destination host unreachable
ld20
When I ping various interfaces from different workstations it says that destination host is unreachable. I am not sure where I did mistake.
Reza Sharifi
Hard to tell without seeing the config and explaining what you have set up but make sure your routing is working correctly.
without your configurations, we cannot tell exact issue. but according to error message, below things can be issues.
1. gateway not configured
2. routers dont have required routes to destination network
Good luck
KB
Hello
Can you post the Packet Tracer file for this lab please
Kind Regards
Paul
