packet tracer activity
fezzpmnt
please help me with commands for configuring on the attached document.
please help i need to finish this in about 1,5hrs from now. your help will be highly appreciated
Deepak Kumar
How can I help you with it? are you looking for configuration? share your pt file as well.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
Deepak Kumar,
I was working on your project, but I saw that the issue has already been resolved.
Either way, since I worked on it, I might as well post the revised project file. I have established end to end connectivity. The file has been saved in the latest Packet Tracer version, version 8.1, so that is the one you need to have installed in order to open the file.
just in case you cannot open the file, here are the configs in text format:
RA#sh run
Building configuration...
Current configuration : 1803 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname RA
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524MPU8-
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 209.165.200.18 255.255.255.248
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.10
description Operations Vlan
encapsulation dot1Q 5
ip address 10.50.1.1 255.255.255.224
ip helper-address 10.50.76.2
interface GigabitEthernet0/1.20
description Finance Vlan
encapsulation dot1Q 6
ip address 10.50.1.33 255.255.255.224
interface GigabitEthernet0/1.40
description Mgmt&native Vlan
encapsulation dot1Q 8 native
ip address 10.50.1.65 255.255.255.224
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 10.50.76.1 255.255.255.252
clock rate 2000000
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface Serial0/1/0
ip address 10.50.76.5 255.255.255.252
clock rate 2000000
interface Serial0/1/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 5
router-id 1.1.1.1
log-adjacency-changes
network 10.50.76.0 0.0.0.3 area 0
network 10.50.76.4 0.0.0.3 area 0
network 10.50.1.0 0.0.0.31 area 0
network 10.50.1.32 0.0.0.31 area 0
network 209.165.200.16 0.0.0.7 area 0
network 209.165.200.8 0.0.0.7 area 0
default-information originate
ip classless
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip flow-export version 9
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
RB#en
RB#sh run
Current configuration : 1381 bytes
version 15.1
hostname RB
ip dhcp excluded-address 10.50.1.1 10.50.1.10
ip dhcp excluded-address 10.50.1.33 10.50.1.42
ip dhcp pool Operations-5
network 10.50.1.0 255.255.255.224
default-router 10.50.1.1
ip dhcp pool Finance-6
network 10.50.1.32 255.255.255.224
default-router 10.50.1.33
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524XHOR-
no ip address
duplex auto
speed auto
shutdown
ip address 10.50.16.1 255.255.255.224
duplex auto
speed auto
standby version 2
standby 65 ip 10.50.16.30
standby 65 priority 110
standby 65 preempt
no ip address
duplex auto
speed auto
shutdown
ip address 10.50.76.2 255.255.255.252
ip address 10.50.76.9 255.255.255.252
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 5
router-id 2.2.2.2
network 10.50.76.8 0.0.0.3 area 0
network 10.50.16.0 0.0.0.31 area 0
ip classless
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
RC#sh run
Current configuration : 1189 bytes
version 15.1
hostname RC
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524ZR0S-
no ip address
duplex auto
speed auto
shutdown
ip address 10.50.16.2 255.255.255.224
duplex auto
speed auto
standby version 2
no ip address
duplex auto
speed auto
shutdown
no ip address
clock rate 2000000
shutdown
ip address 10.50.76.10 255.255.255.252
ip address 10.50.76.6 255.255.255.252
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 5
router-id 3.3.3.3
ip classless
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
S1#sh run
Current configuration : 1573 bytes
version 15.0
hostname S1
no logging console
interface Port-channel1
switchport trunk native vlan 8
switchport mode trunk
interface FastEthernet0/1
channel-group 1 mode active
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
switchport access vlan 5
switchport mode access
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
no ip address
shutdown
interface Vlan5
no ip address
interface Vlan8
ip address 10.50.1.70 255.255.255.224
ip default-gateway 10.50.1.65
line con 0
line vty 0 4
login
line vty 5 15
login
end
S2#sh run
Current configuration : 1535 bytes
version 15.0
hostname S2
no logging console
switchport access vlan 6
interface Vlan1
no ip address
shutdown
interface Vlan8
ip address 10.50.1.71 255.255.255.224
line con 0
line vty 0 4
login
line vty 5 15
login
end
S3#sh run
Current configuration : 1122 bytes
version 15.0
hostname S3
interface Vlan1
ip address 10.50.16.3 255.255.255.224
ip default-gateway 10.50.16.1
line con 0
line vty 0 4
login
line vty 5 15
login
end
S4#sh run
version 15.0
hostname S4
interface Vlan1
ip address 10.50.16.4 255.255.255.224
ip default-gateway 10.50.16.2
line con 0
line vty 0 4
login
line vty 5 15
login
end
