Destination Host Unreachable
olzhik
Hey guys, I'm trying to ping all the PC's to each other, as well as ping and traceroute PC'A' and PC'D' to lo1 and lo99, but for some reason it just gives me the "Destination Host Unreachable" error, how could I fix it?
My ppk file: https://drive.google.com/file/d/1zq5_zGlBRAE05Ee6oqUvHbpaPvcIe7TF/view?usp=sharing
M02@rt37
Hello @olzhik
B1R2-CR-1 routers don't have these serial interfaces configured !
Review all serials interfaces of all routers:
- You have ip address mismatch (you use /30)
- On a serial link only on interface is DCE and the other DTE. Then select DCE interfaces add clock rate to these interfaces. For the others (DTE) delete clock rate command under interface.
- Re configure IP static routes on all routers
After that PCs should ping each other
As an example:
Best regards
M02@rt37
Hello @olzhik
As an example:
Best regards
