Destination NATing...pls help.
manju.cisco
Level 3
Level 3
Hi Everyone,
Today during one of my calls, i got a live request from customer, i didnt know what to do and how to do but i had to take it...........Though i failed to make it success..
I am writing the request i got, please help me on how can i make it success.
I have site A and site B. There is a server on site B which users have to access it from site A LAN.
Customer sends traffic from site A to the server in site B with destination ip as 198.1.1.1/32 (the source network is 204.1.1.0/24).
Acutally the ip 198.1.1.1/32 is the server ip in site B. However, he said he has done some changes (which was not disclosed to us) and he wants to configure NATing in the CE router to NAT the destion ip from 198.1.1.1/32 to 198.1.1.2/32 for those traffic that comes from segment 204.1.1.0/24.
The ip 198.1.1.2/32 is also the ip of the same server.
Here what i understand is customer was trying to do destination NATing on the CE router.
Also to add here is, on the CE router i dont have route to 198.1.1.1/32, and have route from BGP to 198.1.1.2/32. This 198.1.1.2/32 is advertised to CE router by the PE router.
Can someone please analyse this and help me how to configure the NAT properly.
Would appreciate if you can give me the proper commands.
Thanks in advance.
Manjunath.
13 Replies 13
Jon Marshall
It's not really clear from your description.
Are you saying you want any traffic from site A with a source IP of 204.1.1.x going to 198.1.1.1 to be sent to 198.1.1.2 instead ?
If so on the site B CE router which interface is designated as ip nat outside and which interface is designated as ip nat inside.
Jon
Hi Jon
Sorry for late response., late night post.....
There is not nating configured yet on site B. (Site A also has no nating configurations yet)...
What you understood is right.........traffic from site A with source 204.1.1.x going to 198.1.1.1 to be sent to 198.1.1.2
They asked me to implement it on CE router of Site A.
Fa0/0 - Lan port - where we get traffic from 204.1.1.x/24
Se0/0.101 - WAN port 1 to 1st PE
Se0/0.102 - WAN port 2 to 2nd PE.
Would like to say again here that on CE router of Site A, i dont have route to 198.1.1.1/32, and i have route learnt from BGP to 198.1.1.2/32. This 198.1.1.2/32 is  advertised to this CE router by the PE router.
looking for help/suggestions again.....
Apologies, i should have got back to you. I am labbing it up but it is quite difficult to get working so don't feel too bad about not being able to do it
Unlike pix/ASA firewalls where this is a trivial thing to do IOS is not particularly easy when it comes to destination NAT, or at least for me !
When i get some more time i'll lab it up again. I dropped a message to Marwan who has a lot of experience with NAT configs so hopefully he will respond as well.
Jon
Thanks Jon to let me know about this and i wish  i can help
Hi Manjunath wish we can help you to fix your issue
ok  i think the main problem here is that you do not have a route to the actual destination IP and with inside nating the router will try to look into the routing table before translating the IP
so what suggest to do is
remove all your NAT config for this part and do the following :
access-list 108 permit IP 204.1.1.0 0.0.255 host 198.1.1.1
ip route 198.1.1.1 255.255.255.255 [next hop IP of the PE ]
route-map map1 permit 10
match ip address 108
ip nat inside source static 198.1.1.1 198.1.1.2 route-map map1
fa0/0
ip nat inside
s0/0
ip nat outside
s0/0.1
ip nat ouside
s0/0.2
ip nat outside
make sure the next hop PE is ude over one of the above subinterface and that subinterface has the nat outside command as above  where you learn the 198.1.1.2 from
then try and let us know
good luck
Hi Manju,
Marwan solution should work as long as you have the rechability to B end server ip address 198.1.1.1 with nated ip from location A (198.1.1.2.) before configuring the same create a loopback interface with ip address of 198.1.1.2 on site A and try to reach site B server ip by sourcing the traffic from loopback.
Rgds
Rama
even if you dont not have the reachability, the router first need to know where to route the traffic for 198.1.1.1 but after that the router will send the traffic to 198.1.1.2 using the routing table where you have 198.1.1.2 known thorugh routing/PE becuase 198.1.1.1 at the routing/forwarding out stage will be already NATed to 198.1.1.2
anyway once you try it let us know
Hey Jon, many heartly thanks to you for bringing Marwan
Marwan, thank you, i will try that and will post here soon...........
I am sorry for late, due to heavy work at office i didnt find time to come here..........
can you update us if you have tried it yet and if did work or not with you ?
edited
Marwan
I don't think this will work. You have used an "ip nat inside source static" command but your are not natting the source IPs, you are natting the destination IP.
The best i could come up with in the lab was to flip the interfaces ie. fa0/0 interface was "ip nat outside" and the serial interfaces were ip nat inside.
It did do the translation but unfortunately the policy NAT did not kick in ie. i could ping 198.1.1.1 from any address and not just 204.1.1.x
Thoughts ?
Edit - why does destination NAT on IOS have to be so difficult
Jon
The problem is that route-maps are not supported with the "ip nat outside source static ..." command or at least not on my IOS (12.4(21a).
I'm sure Marwan will come up with a NAT config but a workaround is -
int fa0/0
ip nat inside
ip access-group 101 in    <-- see below for explanation
int s0/0  <-- assuming this connects to PE
ip nat outside
ip nat outside source static 198.1.1.2 198.1.1.1 add-route
the above NAT would translate the destination IP of 198.1.1.1 to 198.1.1.2 but from any source IP address ie. not just 204.1.1.x
So to restrict it to just 204.1.1.x source IPs you can apply an acl on the fa0/0 interface ie.
access-list 101 permit ip 204.1.1.0 0.0.0.255 host 198.1.1.1
access-list 101 deny ip any host 198.1.1.1
access-list 101 permit ip any any
The above works but it is admittedly a bit of a mess. A pure NAT solution would be much better and hopefully there is a way that i am missing !
*** Edit - i did try flipping the interfaces ie. fa0/0 becomes "ip nat outside" and s0/0 etc. "ip nat inside". However even though the translation worked for some reason the policy NAT bit didn't so i could still ping 198.1.1.1 from any IP address. The other problem with flipping the interfaces is that if at some time later further NAT is needed chances are they will then be the wrong way round.
Jon
Marwan ALshawi
According to this:
So no need to nat the source subnet just the destination from .1 to .2
