10-21-2019 12:06 AM - edited 10-21-2019 01:55 AM
Hello!
We have a problem with 3650 and 3850 with high CPU, the problem is that we cant detect it in our management systems until the CPU is so high that the switches is not responding to snmp.
Our management systems is only reading the output on "sh process cpu platform" which is very different from "sh process cpu".
Does anyone has an idea how to be able to detect this?
Example:
switch#sh processes cpu sort
CPU utilization for five seconds: 94%/27%; one minute: 95%; five minutes: 95%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
274 59773246 4506120 13264 37.64% 36.07% 36.31% 0 SISF Switcher Th
377 43504784 4954399 8781 28.89% 28.67% 28.75% 0 SISF Main Thread
switch#sh processes cpu plat sorted
CPU utilization for five seconds: 67%, one minute: 54%, five minutes: 52%
Core 0: CPU utilization for five seconds: 50%, one minute: 55%, five minutes: 52%
Core 1: CPU utilization for five seconds: 51%, one minute: 53%, five minutes: 52%
Core 2: CPU utilization for five seconds: 46%, one minute: 53%, five minutes: 51%
Core 3: CPU utilization for five seconds: 59%, one minute: 56%, five minutes: 52%
Pid PPid 5Sec 1Min 5Min Status Size Name
3397 2793 96% 95% 96% R 2135900160 linux_iosd-imag
18694 17000 90% 89% 88% S 2625302528 fed main event
10-21-2019 12:29 AM
Not sure you hitting with Bug. Do you have IPv6 DHCP running or required in the network ? if not follow below steps to resolve the issue :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvk32439/?rfs=iqvred
Workaround:
Remove all configuration related to ip dhcp snooping, run a different IOS version.
configure an IPv6 ACL to drop that traffic in the interfaces (specially the trunk/uplink ports).
ipv6 access-list DENY-IPV6
deny ipv6 any any
Interface gigx/x
ipv6 traffic-filter DENY-IPV6 in
10-21-2019 12:41 AM
Its definitly some kind of bug, disable dhcp snooping is our solution, but that wasnt the question.
1: How can we detect high CPU since we cant read it with snmp
2: Why does cisco not sending the cpu value in snmp ?
(disable ipv6 as mentioned isnt working, disable dhcp snooping is)
10-21-2019 01:10 AM
This is due to CSCus28046.
Raise a TAC Case and get TAC to verify this.
10-21-2019 01:53 AM
10-21-2019 03:04 AM
10-21-2019 03:46 AM
Please read the question again, its not related to WHY we have high CPU, its HOW we can detect it.
10-21-2019 04:46 AM - edited 10-21-2019 04:47 AM
To detect the problem and come to resolution Cisco TAC team need to investigate with you.
This technical Forum can help what best people can base on knowledge and experience.
TAC are the experts on a high level to debug the code and give you the reason why this was a High CPU since we do not have access to your device, Cisco TAC is the best for you.
If you have smartnet contract and its effecting rather than spending time over the forum, raise a TAC case as emergency for the solution.(if i were you i would do the same thing)
10-21-2019 05:52 AM
Can I be clearer?
"base on knowledge and experience" is there a way to know if switches are having high CPU, or are the rest of you also sitting in the dark and waiting for an accident to happen?
I want to be proactive and not be totally in the dark of theese things.
10-21-2019 06:30 AM
Sure you can do many ways -
1. Send information to SYSLOG Server
2. use EEM Script to report over email or trap to SYSLOG
10-21-2019 07:35 AM
on a side note, you could use the script below to have the switch proactively send you an email when the CPU reaches a certain treshold (80 percent in the example, and the switch is polled every 5 seconds).
logging buffered 8192 informational
process cpu threshold type total rising 80 interval 5
event manager applet High_CPU authorization bypass
event syslog occurs 1 pattern "CPURISINGTHRESHOLD"
action 1.0 info type routername
action 2.0 syslog msg "High CPU utilization detected on $_info_routername"
action 3.0 mail server "201.222.223.12" to "user-to@domain.com" from "user-from@domain.com" subject "High CPU Alert on $_info_routername" body "$_syslog_msg"
10-21-2019 03:21 PM
10-21-2019 02:32 PM
Raise a TAC Case and ask TAC that very question.
10-21-2019 06:07 AM
10-21-2019 08:45 AM
on a side note, you can proactively configure the below on the switch(es), and you will get an email from from the switch informing you of high CPU utilization. In the example, the threshold is set to 80 percent.
