Devices behind Access switch 2960 not getting IP from DHCP
The devices connected to 2960 are not getting ip addresses from windows dhcp server. IP helper is already configured. Below is the brief core and access switches config.
Core:
interface Port-channel1
description ** Uplink to Access Switches **
switchport mode trunk
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface GigabitEthernet2/0/47
description ** Uplink to Access-Switch **
interface Vlan1
interface Vlan2
ip dhcp relay information trusted
ip address 172.16.16.1 255.255.255.0
ip helper-address 192.168.1.2
interface Vlan5
ip address 172.16.225.1 255.255.255.0
interface Vlan10
ip address 192.168.2.1 255.255.255.0
Access-Switch:
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet1/0/1
switchport access vlan 2
switchport mode access
switchport voice vlan 1
spanning-tree portfast
interface GigabitEthernet1/0/24
description **Uplink to Core**
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.2.6 255.255.255.0
ip default-gateway 192.168.2.1
Firstly try ping dhcp server, do you seccuss?
the configuration of your access switch won't work. You can only have one active (management) Vlan interface on a layer 2 (access) switch. On the access switch, shut interface Vlan 1. Also, I would use a different Vlan the Vlan 1 as voice Vlan.
interface Vlan1
no ip address
--> shut
And put the ip helper information on the core switch only:
interface Vlan1
--> ip dhcp relay information trusted
--> ip helper-address 192.168.1.2
interface Vlan2
interface Vlan5
interface Vlan10
