DHCP binding for vendor specific
Jeff Horton
Level 3
Level 3
This may not be configurable but I had to ask in order to correctly answer someone's question...
I have a pool of ip addresses in a DHCP pool.. I want to reserve a portion of them for a vendor specific hardware address.. Can this be done on Cisco switch?
Pool is 192.168.1.0 255.255.255.0
reserved needed is 192.168.1.120 - 150 for vendor specific hardware address..
What they are needing to do is be able to change out a bad device with a good device and only retrieve an address from the reserved pool.. Trying to keep ip addresses specific to certain devices on the LAN...
Thanks in advance...
Jeff
You could try DHCP Option 60. DHCP Option 60 is the Vendor Class Identifier (VCI). The VCI is a text string that uniquely identifies a type of vendor device.
11 Replies 11
Leo Laohoo
You mean DHCP reservation?
Not sure how exactly to do this.. would reservation be best?
Jeff
If you want it simple, yes.
Then reservation it is.. How do I configure the DHCP to recognize the vendor portion of the hardware address to give it a certain range of addresses within a subnet?
You will need to enter the complete MAC address to the assigned IP address.
I understand that portion of my question but how do you configure dhcp to recognize the vendor portion of the MAC only?
You have to configure the reservations (i.e. IP to MAC) it does nothing to 'recognise' OUI.
If you want addresses to be dynamically issued to them, you need to look toward the aforementioned client-identifier.
Martin
Have you used client-identifier for this before?
Does the IE 3000 or IE 4000 support dhcp option 60? Having trouble with the correct configuration..
IT should but I haven't tried it.
