DHCP binding not working
gmolinero
Community Member
Hello all,
Since this morning, I am having problems accessing internet and I dont know why..
I have a cisco 2900 router as dhcp server to give access to a LAN pool 192.168.10.0 /24, moreover we need to do PAT translation to a coorporate LAN 172.17.103.59 255.255.255.192.
router is directly connected with a aironet Access point with static mac-address access list.
DHCP bindings in the 2900 are registered for some users (some celulars and some laptops); In my case, my iphone can access internet and is registered in the dhcp bindings table, however my laptop is registered in the dhcp binding table but I am unable to access internet.
I have made dhcp and nat debugs but I can not find interesing info to solve this issue.
I am attaching the 2900 configuration:
ip dhcp excluded-address 192.168.10.12
ip dhcp pool GregoPOOL
network 192.168.10.0 255.255.255.0
domain-name Grego
dns-server 8.8.8.8 8.8.4.4
default-router 192.168.10.1
lease 0 2
update arp
interface GigabitEthernet0/0
ip address 172.17.103.60 255.255.255.192
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/0/0
ip address 192.168.10.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat pool FUERA 172.17.103.59 172.17.103.59 netmask 255.255.255.192
ip nat inside source list 7 pool FUERA overload
ip route 0.0.0.0 0.0.0.0 172.17.103.61
access-list 7 permit 192.168.10.0 0.0.0.63
Could someone give me a light about this issue?
Thanks!!!
acampbell
Your DHCP pool is allowing addresses 192.168.10.1 - 254 (except 12)
Your NAT access list is only allowing addresses
192.168.10.1 - 62 to be NATTED (access-list 7 permit 192.168.10.0 0.0.0.63)
Are your failed DHCP clients above Ip address 62
May be you need to allow more addresses through the acess list
Changing to "access-list 7 permit 192.168.10.0 0.0.0.255" will allow the full subnet.
You should also exclude your router interface from the DHCP
Alex
Regards, Alex. Please rate useful posts.
acampbell
Alex
I changed the subnet and I got access. Thanks
However dhcp bindings are still not working fine. Some PCs are registered and some of them not. Maybe is a Windows 7 issue with the dhcp client.
By other hand, I think that the cisco router 2900 is to slow making these bindings to the dhcp table.
Do you know something about this?
Thanks!
You have opted to use "Secure DHCP" by the update arp command under your
DHCP pool.
You have also put your devices on a short lease 2 hours.
This MAY be causing a rise in CPU utilisation.
You could try setting your lease back to the ONE day default
no lease 0 2
See if that speeds thing up a bit.
Alex
swasthik_ms87
Community Member
Are you getting DHCP requests to this Router from the clients ? Also double check service dhcp is enabled on the box(it would be a hidden command depends on IOS version). It would be safer to check for any dhcp conflicts occured.
Also, is this issue started after enabling NAT on GigabitEthernet0/0/0 ?
