DHCP Conflicts on Core Switch
sathish.062
Hi Friend,
I am facing issue with one of IP DHCP scope, IP's are conflicting. The scope is configured on Core Switch. Please find below-required information.
Please help me to find the solution.
interface Vlan40
description "VOICE0 10.220.31.128/26"
ip address 10.220.31.129 255.255.255.192
ip pim sparse-dense-mode
ip igmp version 3
end
Pool VLAN40_VOICE0 :
Utilization mark (high/low)    : 100 / 0
Subnet size (first/next)       : 0 / 0
Total addresses                : 62
Leased addresses               : 15
Excluded addresses             : 17
Pending event                  : none
1 subnet is currently in the pool :
Current index        IP address range                    Leased/Excluded/Total
10.220.31.161        10.220.31.129    - 10.220.31.190     15    / 17    / 62
ip dhcp pool VLAN40_VOICE0
   network 10.220.31.128 255.255.255.192
   default-router 10.220.31.129
   dns-server 10.220.31.19 10.220.70.121
   option 150 ip 10.220.70.67 10.220.70.68 10.220.22.160
004384: Aug  7 2018 22:28:59.060 EDT: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 10.220.31.156.
004385: Aug  7 2018 22:29:00.066 EDT: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 10.220.31.157.
004386: Aug  7 2018 22:29:01.073 EDT: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 10.220.31.158.
004387: Aug  7 2018 22:29:02.088 EDT: %DHCPD-4-PING_CONFLICT: DHCP address conflict:  server pinged 10.220.31.159.
6 Replies 6
It seems that the switch has been reloaded and forgot the leases. As a result, the switch tried to assign IP addresses which were already being used and you got the messages.
Use "clear ip dhcp conflict *" to clear the IP address conflicts and try again.
P.S.:- Please rate helpful answers and solve it once you get the correct solution.
HTH,
Meheretab
HTH,
Meheretab
andresfr
Hello Sathish,
What's happening is that the Core switch  will ping the IP address it intends to allocate to a client before replying to the DHCP request. If the router receives ICMP Echo Reply message (response to ping), the address is obviously in use. If the DHCP conflict logging is enabled (default), the router will log the conflict with a syslog message (not in a separate log file) and put the address on the list of conflicts. The addresses on that list (displayed with show ip dhcp conflict) are not used in the future (similar to the addresses configured with the ip dhcp excluded-addresses command). To reuse a conflicting address, the network operator has to remove it from the list with the clear ip dhcp conflict address (or * for all addresses) command.
Action Plan:
1. Run the following command and share the output
2. To reuse conflicting IP address run the following:
3. Check if you have DHCP database agent configured:
show run | i ip dhcp database
4. If you don't have DHCP databa agent configured (the previous command will return no output) then the solution will be to disable the conflict logging  feature with the no ip dhcp conflict logging configuration command. Even without conflict logging, there's no DHCP functionality loss and no chance of duplicate address allocation, as the router would still check whether an IP address is active before allocating it (and later on, it would be willing to re-check the conflicting IP address).
configure terminal
 end
wr
If you don't use DHCP database agents and you don't disable conflict logging (default setup), you'll have to clear the conflicts manually after a reload and you might potentially exhaust the DHCP pool because of a large number of blocked conflicting addresses.
Similar post:
https://community.cisco.com/t5/routing/dhcp-database-agent/td-p/896134
Documentation just for reference:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_dhcp/configuration/dhcp-xe-3se-3650-book/config-dhcp-server.html#GUID-5F022CF5-671E-49E7-8FBD-69997EEBC730
Seb Rupik
Hi there,
Had the core switch been reload prior to you seeing these messages?
They are generated when the DHCP server process tries to allocate an IP address which it believes is free (according to its internal database) but finds it is not.
The fix is to store the DHCP database in a permanent location, either on local flash or remotely (eg TFTP, FTP) so that DHCP lease state is preserved.
cheers,
Seb.
Thanks for your reply. Core Switch was rebooted 7 days before but we are facing this for last 2 days. Let me try what you have suggested.
This starts when dhcp leases begin to expire on device.
Then devices will start to claim a renew of their address, the switch will ping it and so mark it as conflict because already up in the network.
You have to store the database lease on the flash in order to keep it resilient to reload of the switch :
ip dhcp database flash://dhcp-leases
Jérôme
Hello Sathish,
I hope you're doing great.
Did you have a chance to test the suggested actions?
Please don't forget to share your results so other can benefit as well and consider rating the post.
