DHCP doesn't work on Community Vlan
mterlikcisco
I play with brand new C3750X on 12.2(58) if I remember right.
I set up DHCP pool, private vlan - primary and secondary.
For Primary Vlan I created isolated vlan and community vlan. I associated Primary vlans with (I) and (C) secondary vlans.
Next I set interfaces with Primary Isolated and another interface with Primary Community,
Created SVI with IP address.
The wired think is that DHCP pool is working fine on isolated ports, but does not when I plug hosts in to community vlans. When I set static IPs I can ping from host A to host B in community vlan. I run DHCP debugging and I do not see any records when I test it in the community secondary vlan.
I reset DHCP service, cleared bindings,
I check configuration maybe I am missing something but I at this moment I do not know where to look for. Is there a way I can troubleshoot it.
2 Accepted Solutions
Abzal
Level 7
Level 7
Abzal
Level 7
Level 7
You are welcome. Glad to help.
Please mark hepful posts.
Sent from Cisco Technical Support Android App
Best regards,
Abzal
Abzal
Level 7
Level 7
Switch configuration would help.
http://www.cisco.com/en/US/docs/switches/metro/me3400/software/release/12.2_50_se/configuration/guide/swpvlan.html#wp1038472
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Thanks, I will check the settings, but from I read in that article I think I missed this part http://www.cisco.com/en/US/docs/switches/metro/me3400/software/release/12.2_50_se/configuration/guide/swpvlan.html#wp1077199
I associated community Vlan with primary Vlan but not with SVI interface. I just don't remember i did this step.
mterlikcisco
Yep, That was a problem
I tested configuratin and after I add
Vlan10 - Primary VLAN
Vlan101 - secondary Isolated VLAN
Vlan100 - secondary Community VLAN
I has
interface Vlan10
ip address 10.10.20.1 255.255.255.0
private-vlan mapping 101
I added
interface Vlan10
private-vlan mapping 101,100
and it works now.
Thank you Abzal for advice!
Abzal
Level 7
Level 7
Best regards,
Abzal
