DHCP for IP Phone on Cisco Router - 4331 Doesn't work + Cisco 887 Does work
darreng
I have a Cisco 4331 router that was configured with as a DHCP server for a small pool of Mitel iP Phones. The config of this router is a s follows:
ip dhcp excluded-address 172.20.2.139 172.20.2.142
ip dhcp pool Voice
 network 172.20.2.128 255.255.255.240
 default-router 172.20.2.142
 domain-name xyz.com
 option 43 ascii "id:ipphone.mitel.com;sw_tftp=10.104.0.2;10.103.0.2;call_srv=10.104.0.2;vlan=20;l2p=6v6s6;dscp=46v46s2"
The main LAN interface on the 4331 is setup as a dot1q trunk for VLAN’s 10 (Data) and 20 (Voice). The router makes a DHCP offer but the Mitel IP phone never accepts it, another DHCP request is then made by the IP Phone. The output of ‘show ip dhcp binding’ on the router shows the router offering the IP to be allocated e.g.
RTR01#sh ip dhcp bind
Bindings from all pools not associated with VRF:
IP address      Client-ID/              Lease expiration        Type       State      Interface
Hardware address/
User name
172.20.2.133    0108.000f.ba4c.30       Nov 02 2017 09:52 PM    Automatic  Selecting  GigabitEthernet0/0/0.20
I move the same DHCP config to a Cisco 887 creating VLAN 10 and 20 and trunking them on Fa0 to the switch and it works fine.
The internal switch is a HP 2920 that is configured to trunk VLAN 10 and 20 back to the respective routers. The keyword ‘voice’ is configured VLAN 20 on the HP.
Using Wireshark (port mirrored from the phone directly) the only difference I can see in the DHCP offer between the 2 x router types is that on the 4331 Option 61 (Client - ID) is in the DHCP Offer reply to the IP Phone (the phone MAC).
In the 887 I don’t see option 61 in the DHCP Offer reply. Should this even matter.
I should have connected the 887 to the same port on the switch as the 4331 and re-tested but the VLAN trunking is the same on the separate ports back to the respective routers.
Can anyone offer an opinion. It’s driving me mad. Better still has anyone got a Cisco 4K config they can share that provides DHCP for a Mitel setup.
Many thanks for taking time to read.
Darren
5 Replies 5
Hi @darreng
Not sure why it is necessary to add dscp on the dhcp option if you are not using QoS, but, I've seen others example where the option for dscp is dscp=46v46s26.
If possible, try to share both switches config so that maybe we can see something you're missing.
-If I helped you somehow, please, rate it as useful.-
Hi Flavio,
Thank you for taking the time to reply. Rather than send the whole switch and router config, I have summarised the key config snippets below. DHCP config is as per the original post on this router.
Port 1/1 on the HP switch stack that shows an IP phone plugged in. Other phones are plugged into the switch, the same config is repeated on those ports.
E.g. VLAN 10 (untagged) and VLAN 20 tagged towards the phone.
STACK-01# sh vlan port 1/1 de
15:19:59 Status and Counters - VLAN Information - for ports 1/1
Port name: Voice Port
VLAN ID Name                 | Status     Voice Jumbo Mode
10      DATA                 | Port-based No    No    Untagged
20      VOICE                | Port-based Yes   No    Tagged
STACK-01# sh cdp neigh de
 CDP neighbors information
  Port : 1/1
  Device ID : 00 00 00 00 00
  Address Type : UNKNOWN
  Address      : Unsupported format
  Platform     : MITEL 5320 IP,h/w rev 0,ASIC rev 1,f/w Boot 06.01.00.09,...
  Capability   : Switch
  Device Port  : LAN port
  Version      : MITEL 5320 IP,h/w rev 0,ASIC rev 1,f/w Boot 06.01.00.09,...
  Port : 1/1
  Device ID : SEP08000FBA5A70
  Address Type : IP
  Address      : 192.168.1.10
  Platform     : M6020001
  Capability   :
  Device Port  : Port 1
  Version      : M6020001
VLAN 10 & 20 config, note the router is in port 1/48.
STACK-01# sh run vlan 10
Running configuration:
vlan 10
   name "DATA"
   tagged 1/48,4/48,Trk1-Trk2
   untagged 1/1-1/44,2/1-2/44,3/1-3/43,4/1-4/44
   no ip address
   spanning-tree instance 1
   exit
STACK-01# sh run vlan 20
vlan 20
   name "VOICE"
   tagged 1/1-1/2,1/48,2/1-2/3,3/1-3/3,4/1-4/3,4/48
   no ip address
   voice
   exit
Router configuration shows VLAN 10 and 20 trunked.
interface GigabitEthernet0/0/0.10
 description Data VLAN
 encapsulation dot1Q 10
 ip address 10.1.219.252 255.255.254.0
 no ip redirects
 ip nat inside
 standby 10 ip 10.1.219.254
 standby 10 priority 105
 standby 10 preempt delay minimum 25
 standby 10 track 1 decrement 10
interface GigabitEthernet0/0/0.20
 description VOICE VLAN
 encapsulation dot1Q 20
 ip address 172.20.2.140 255.255.255.240
 no ip redirects
 ip nat inside
 standby 20 ip 172.20.2.142
 standby 20 priority 105
 standby 20 preempt delay minimum 25
 standby 20 track 1 decrement 10
Darren
charleswatkins
I have the same issue as you when running ios xe 16.9.1 with Mitel phones. When the main load of the phones is at 06.02.00.01 dhcp will not work. If you upgrade the phones to 06.04.01.07 it will work. I speculate that the phones are dropping the DHCP Offer because the Client ID is passed back to them in the offer. I believe upgrading the phones gets them in compliance with RFC6842 in which the client identifier must be included in the DHCP offer if it is provided by the client. In the older RFC 2131, the server should not include the client identifier in the offer message.
Hello
does access port include the both data/voice vlans
is a pc able to obtain dhcp address from the voice vlan scope
On the access port try
disable cdp
enable portfast
Kind Regards
Paul
Apologies for my delayed response to all those who replied. I haven’t been on the community forums for a while.
In the end we left the 887 providing the DHCP for the site in question. I’ll lab up the recommended changes above to see how things work out.
Thanks to to all for taking the time to reply.
Darren
