DHCP for PC at g0/1 from g0/0 for cisco 1941
phuayhow01
Hi all,
     I have this cisco 1941 router with two ethernet ports g0/0 and g0/1. The g0/0 is connected to office LAN with internet access. As my office LAN is DHCP, it will assigned a IP address for g0/0 since this g0/0 is configured as "ip address dhcp". Now my question is that i have a group of 5 pcs, namely PC1, PC2, PC3, PC4 and PC5 that is connected to the switch and one of the ports of this switch is connected to g0/1 of cisco 1941. Is it possible that let say PC2 and PC3 (both DHCP enabled) could access the internet access from g0/0 and at the same time, the office LAN assigned IP address for PC2 and PC3 automatically?
                                                       Office Lan with internet access (DHCP) (Default gateway 10.0.0.1)
                                                        g0/0 (DHCP enable) (DHCP assigned IP address 10.0.0.138)
        Cisco router 1941
        g0/1
        HP Switch
        PC1 PC2 PC3 PC4 PC5
       As i am a newbie, is this operation possible? if possible, could somone guide me how to configure inside the router 1941 to achieve this objective?
Thank and Regards,
Raymond
2 Accepted Solutions
Hi Raymond,
1) I use one of the PC5 which has the static ip address of 10.10.10.4, 255.255.255.0, default gateway 10.10.10.1, i could get a reply from 8.8.8.8 after i perform a ping function but when i surf the internet using internet explorer, it cannot. Any idea what happened
A) This could be issue with the dns. Please check what is the dns configured on the PC? Try setting the DNS as 4.2.2.2 on the PC and try browsing the internet.
2) When i switch PC5 from static ip address to dhcp mode (select obtain the ip address automatically), it failed to do so. Any idea what needed to configure inside the router to solve this issue?
A) If you expecting the PC to pick ip address from DHCP server enabled on internet access device, that is not going to work as they are not different ip subnet. You could enable the router 1941 to act as a DHCP server and ensure the clients pick ip address from it. A typical configuration would be as below.
conf terminal
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool DATA
network 10.10.10.0 255.255.255.0
dns-server 4.2.2.2 10.0.0.1
default-router 10.10.10.1
Najaf
Please rate when applicable or helpful !!!
kcnajaf
Level 7
Level 7
4.2.2.2 is a public DNS server. In Internet everything works on ip address. When you browse Internet you use names like google.com. This name had to be covered to the ip address for which we use DNS servers.
To answer your second question I need to understand if you have access to the Internet device? What device is it? Does it have option to configure multiple DHCP scopes etc...
Najaf
11 Replies 11
kcnajaf
Level 7
Level 7
Hi Raymond,
Yes it will be possible as long a NATing is enabled on the Cisco Router 1941.
A typical configuration would be as below. Please modify ip address as per your requirment.
interface Gig0/0
ip address 10.0.0.1 255.255.255.128
ip nat outside
interface Gig0/1
ip address 10.0.0.130 255.255.255.128
ip nat inside
ip nat inside source list 1 interface Gig 0/0 overload
access-list 1 permit 10.0.0.128 0.0.0.128
ip route 0.0.0.0 0.0.0.0 x.x.x.x (Gateway for internet)
Hope that helps.
Najaf
Hi najaf,
    Thank for your swift reply. There is slightly changes to my previous setup. My latest setup is as followed:
                            Office Lan with internet access (DHCP) (internet default gateway 10.0.0.1)
                                                        g0/1 (DHCP enable) (DHCP assigned IP address 10.0.0.138)
        Cisco router 1941
        g0/0 (10.10.10.1 255.255.255.0)
        HP Switch
        PC1 PC2 PC3 PC4 PC5 (10.10.10.4)
     When i type command "show interface g0/1" inside the cisco router 1941, i could see that g0/1 has been assigned a ip address of 10.0.0.138.
Below is my full router configuration:
Current configuration : 3386 bytes
! Last configuration change at 08:22:14 UTC Wed Mar 13 2013 by cisco
version 15.1
service password-encryption
hostname Pioneer
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-625968446
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-625968446
revocation-check none
rsakeypair TP-self-signed-625968446
crypto pki certificate chain TP-self-signed-625968446
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 36323539 36383434 36301E17 0D313231 31323830 36313231
  385A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
username cisco secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address dhcp
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 10.0.0.2
access-list 1 permit any
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
        I use one of the PC5 which has the static ip address of 10.10.10.4, 255.255.255.0, default gateway 10.10.10.1, i could get a reply from 8.8.8.8 after i perform a ping function but when i surf the internet using internet explorer, it cannot. Any idea what happened?
Thank and Regards,
Raymond
Hi Raymond,
conf terminal
ip dhcp pool DATA
Najaf
Hi Najar,
     I could surf now after setting the DNS to 4.2.2.2. As i am newbie, could i know what is dns 4.2.2.2?
    For point 2, if i do not want to configure my router 1941 as a dhcp server, is there a way for PC5 to obtain an ip address directly from my office LAN via g0/0?
Raymond
kcnajaf
Level 7
Level 7
Najaf
Hi Najaf,
     I cannot access to the internet device as it belongs to my service provider.
     But anyway, Thank for your explanation.
Raymond
Hi Raymond,
If you dont have access to internet device then you are better of running your own DHCP server:-)
Najaf
Hi Najar,
     Thank for your advice.
Raymond
hksantosh10
My setup is bit same as the above.I am using router in between the servers.
find the below details:
server1 ->(GE0/1) Router (GE0/0)<- Server 2
I want to transfer packets from server1 to server2 and vice versa.
can anyone please share the router ip configurations for GE0/0 n GE0/1.
Waiting for your reply champs.....
there is nothing special to do unless you configured ACLs or the IOS stateful firewall on the router and as long as each server has the correct route to communicate with the other one.
Alain
Hi Cadet,
Thanks much for the reply.
I have configured the ip's as below.
server1 (10.0.0.7)->GE0/1 (10.0.0.1) Router GE0/1 (20.0.0.1) <- server2 (20.0.0.6).
I am able to ping from server1 to router and vice versa but unable to do it from server2.
I have tried with same subnet(GE0/1 & GE0/0/)  but router through an error.
If you need any further information please let me know. i will share it.
It will be helpful if you share commands or any links.I am beginner in router configuration.
PS: I am transfering X25 packets from server1 to server2 through router.
Santosh
