Unable to do multiple destination port for SPAN 4506 switch
eddie5170
Can anyone help me to figure out why on my 4506 Catalyst L3 switch i am unable to SPAN on multiple destination port on session 2, but on my 3560 switch I can do multiple destination ports? See below in red for the error
Session 1
Type                   : Local Session
Source VLANs           :
    RX Only            : 2034-2035
Destination Ports      : Gi3/41
    Encapsulation      : Native
          Ingress      : Disabled
         Learning : Disabled
Filter Pkt Type        :
    RX Only       : Good
Session 2
Source VLANs           :
    RX Only            : 2035
Destination Ports      : Gi3/48
    Encapsulation      : DOT1Q
          Ingress      : Disabled
         Learning : Disabled
Filter Pkt Type        :
    RX Only       : Good
NSEVCisco4500(config)#monitor session 2 destination int gi3/47
% This platform allows a maximum of 1 monitor destination(s)
IOS Version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.01.01.SG RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 14-Dec-10 21:30 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
Image text-base: 0x1009E914, data-base: 0x13B71550
ROM: 15.0(1r)SG2
Jawa Revision 7, Snowtrooper Revision 0x0.0x15
Directory of bootflash:/
72962  -rw-    85229120  Jun 19 2011 23:19:43 +00:00  cat4500e-universal.SPA.03.01.01.SG.150-1.XO1.bin
Thank
nkarpysh
That is platform HW restriction:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/15.02SG/configuration/guide/span.html#wp1020415
"SPAN is limited to one destination port per session."
Niko
HTH,
Niko
So you are saying that the 3560 switch can do multiple destination ports and our newer 4506 switch can only do 1 destination port? How can we SPAN it to multiple destination port like the 3560 with only one source vlan ? We were told from a cisco rep that it can handle at least 8 destination port for SPAN.
This is our monitor session for our 3560:
Session 1
Source VLANs           :
    RX Only            : 2034-2035
Destination Ports      : Gi0/43
          Ingress      : Disabled
Session 2
Source VLANs           :
    RX Only            : 2035
Destination Ports      : Gi0/8,Gi0/23,Gi0/25,Gi0/27,Gi0/31,Gi0/47
          Ingress      : Disabled
Eddie
paolo bevilacqua
Wrong forum, post in ""Lan and switching". You can move your posting with the Actions panel on the right.
