DHCP Help
ryancdavis
Current configuration on a cisco 2921 (Verson 15.0(1r)M9 Release (fc1)):
ip dhcp pool Voice
network 10.21.179.0 255.255.255.128
default-router 10.21.179.1
option 150 ip 10.21.179.196 10.21.179.200
Issue is when a device looks to renew their lease no IP's are available.  Debug ip dhcp events tells me the dhcp pool is exhausted.  It appears that when the devices, Cisco phones in this case,  goes to renew their lease, they do not renew with the current IP they already have.  This causes the pool to become exhausted of ip addresses.  For some reason, the router holds the IP's in reserved status and will not reassign them back out for a specific amout of time.
Anyone have any ideas?
6 Replies 6
ankugarg
Level 7
Level 7
Can you post the full running config ?
cadet alain
If you haven't got thousands of phones  then assign them static bindings for their specific  mac-addresses
ip dhcp pool PHONE1
  host x.x.x.x
hardware-address xxxx.xxxx.xxxx
and so on for each phone keeping the parent pool with all the settings then each child pool will inherit these: default-router, tftp server,...
Regards.
Alain.
johnlloyd_13
Level 11
Level 11
In addition to what others have suggested, why not shorten the DHCP lease time?
You really have two choices:
Decrease your dhcp timer.
Increase your dhcp scope.
If you have more devices than your scope allows, you're going to see this problem over and over.
If you don't, then just decreasing the time the router keeps the mac address assigned to the ip will do the trick.
Ven
Ven Taylor
What's the command for decreasing the dhcp timer.
Tac suggested I use the command "no ip dhcp conflict logging."
hi ryan,
thanks for the rating! kindly use the DHCP command below. default is 24 hours or 1 day.
Router(dhcp-config)#lease
