DHCP isssues
satya mothukuri
we are having issue with our core swich which acting as DHCP for all users and AP.
I am seeing selecting when i issue
sh ip dh binding | in Vlan60
10.227.170.4 0100.f663.464c.a8 Apr 16 2018 12:56 PM Automatic Selecting Vlan60
10.227.170.26 0100.81c4.84b2.54 Apr 16 2018 12:56 PM Automatic Selecting Vlan60
10.227.170.27 0100.81c4.8eb3.c8 Apr 16 2018 12:56 PM Automatic Selecting Vlan60
10.227.170.28 0100.2a10.6e3f.c0 Apr 16 2018 12:56 PM Automatic Selecting Vlan60
10.227.170.29 0100.f663.52f2.e0 Apr 16 2018 12:56 PM Automatic Selecting Vlan60
10.227.170.30 0100.2a10.33da.d0 Apr 16 2018 12:56 PM Automatic Selecting Vlan60
we are using
Model Number : WS-C3650-24TD
Ver: Version 03.06.04.E RELEASE
No conflicts observed. this happened all of sudden, no changes made.
Much appreciated if any help.
Diana Karolina Rojas
First of all I recommend you to remove the DHCP from your device and put it into a server, do you have many users? when it occurs all the dhcp clients loos conectivity or only a few? It seem like the device loos the binding.
-----Do not forget to rate useful answers-----
Thanks for reply.
I didn't get "remove the DHCP from your device and put it into a server,"
when the issue happened, few of the user got IP from DHCP. if we set IP manually on the AP, it works fine.
do you have DHCP snooping enabled by any chance ?
Post the config of your switch, we might spot something...
We didn't enable DHCP snooping
