DHCP issue in 2960 and unmanageable switch
kri.chi.85
Dear Team,
I am having 2960 switch and one port is configured with a VLAN and connected with an unmanageable switch and further one more unmanageable switch was connected to the primary unmanageable switch…
The topology will be    2960 switch -> unmanageable Switch -> unmanageable -> PC connected
The issue I am facing most of the PC are getting IP addresses through DHCP server and very few 5 or 6 PC’s out are not getting the IP from DHCP server.
If I switch of the switch and switch on the issue is resolved for those and it will raise for some other PC’s.
Thanks you team......
eLiAsAn41
May I have your Physical Topology? I want to know where the DHCP Server Located? And what brand of the Unmanageable Switch are?
ALIAOF_
Level 6
Level 6
This is the same post as this: https://supportforums.cisco.com/message/3776014#3776014
Before someone can help you, you'll have to provide the requested information so that that people can make suggestions accordingly.  Help us help you
