DHCP NAK
bluesea2010
Level 5
Level 5
Hi ,
Pc is not getting ip address .In the wireshark capture  DHCP serve giving 'NAK ' . This started to happen after replacing cisco switches
mariano.alfonso
What model are the switches? Could you please paste the DHCP config?
hI Edge switch is WS-C4510R+E
Distribution switch is vss enabled 6807
interface Vlan18
 ip address 10.0.99.1 255.255.255.0
 ip access-group tesing out
 ip helper-address 192.168.8.8
