DHCP not obtained on Vlan
wilmottech
I'm trying to figure out why the DHCP is not being handed out on Vlan 1303.  I have a DHCP server on Vlan 1300 that's working fine, but I have DCHP setup on an 800 series ISR and am not getting an IP address handed out.  I have fastethernet2 setup on vlan 1303.  When I enter a static IP into the machine it works fine.
I've copied the parts I think that are needed for this below:
ip dhcp excluded-address 192.168.168.1 192.168.168.127
ip dhcp pool vlan1303
 network 192.168.168.0 255.255.255.0
 default-router 192.168.168.1
 dns-server 192.168.168.1
interface FastEthernet0
 description a0-1000-r223.distribution.gi30
 switchport trunk native vlan 1300
 switchport mode trunk
 no ip address
interface FastEthernet1
 description tz300.x1
 no ip address
interface FastEthernet2
switchport access vlan 1303
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
interface FastEthernet5
 no ip address
interface FastEthernet6
 no ip address
interface FastEthernet7
 no ip address
interface Vlan1303
 ip address 192.168.168.1 255.255.255.0
 ip access-group vlan1303-in in
 ip nat inside
 ip virtual-reassembly in
ip access-list extended vlan1303-in
 permit tcp any 192.168.0.0 0.0.0.255 eq 443
 permit tcp any host 192.168.0.220 eq 3389
 permit udp any any eq domain
 permit tcp any any eq domain
 permit udp any any eq bootpc
 permit udp any any eq bootps
 deny   ip any 192.168.0.0 0.0.255.255
 deny   ip any 172.0.0.0 0.240.255.255
 deny   ip any 10.0.0.0 0.255.255.255
 permit ip any any
22 Replies 22
amikat
Level 7
Level 7
Will you please add the command "ip helper-address address_of_your_DHCP_server _at_Vlan1300" under the "Interface Vlan1303".
Best regards,
Antonin
Antonin makes an interesting suggestion about using helper address. If they have configured the DHCP scope on the router I doubt that there is also a scope for that network on the server. But perhaps they can move the scope to the server and solve the issue that way.
Rick
Rick
I did this as well and it did not resolve the issue.
Here's a full dump of what's in my ISR, public IPs are altered:
boot-start-marker
boot-end-marker
logging buffered 4096
logging persistent
logging monitor informational
aaa new-model
aaa authentication login default local
aaa authentication enable default none
aaa authentication ppp vpdn_auth group radius
aaa authorization network default group radius
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
ip source-route
ip cef
ip flow-cache timeout inactive 60
ip flow-cache timeout active 1
ip domain name company.local
ip name-server xxx.xxx.x.x
ip inspect name fw tcp
ip inspect name fw udp
ip inspect name fw icmp
ip inspect name fw dns
ip inspect name fw tacacs
ip inspect name fw tacacs-ds
ip inspect name fw l2tp
ipv6 unicast-routing
ipv6 cef
vpdn enable
vpdn-group L2TP
 ! Default L2TP VPDN group
 accept-dialin
  protocol l2tp
  virtual-template 1
 no l2tp tunnel authentication
license udi pid CISCO891-K9 sn FGL164623MY
object-group network facs-hosts
 host yyy.yy.yy.yyy
object-group network infrastructure
 host 192.168.0.4
object-group network level3.dns
 host xxx.xxx.x.x
 host xxx.xxx.x.x
object-group network mgmt-hosts
 host zzz.zz.zz.zz
 host  zzz.zz.zz.zz.
host zzz.zz.zz.zz.!
object-group network servers
 range 192.168.0.200 192.168.0.254
 range 192.168.0.200 192.168.0.229
 host 192.168.0.44
 host 192.168.0.71
 host 192.168.0.35
 host 192.168.0.67
 host 192.168.0.60
 host 192.168.0.38
no spanning-tree vlan 1300
vtp mode transparent
vlan 1300,1302-1307
crypto isakmp policy 2
 encr 3des
 authentication pre-share
 group 2
crypto isakmp policy 10
 encr aes
 group 2
 lifetime 28800
crypto isakmp key weBu6puww address ff.ff.ff.ff
crypto isakmp key QT359ybruk address ff.ff.ff.ff
crypto isakmp key HEeKd5ewUs address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 10
crypto ipsec transform-set default_windows esp-aes esp-sha-hmac
crypto ipsec transform-set ipsec_dyn_ts esp-3des esp-md5-hmac
crypto ipsec transform-set L2TP esp-3des esp-sha-hmac
 mode transport
crypto dynamic-map L2TP_dm 1000
 set transform-set L2TP
crypto dynamic-map ipsec_dyn 10
 set security-association lifetime seconds 86400
 set transform-set ipsec_dyn_ts
 match address ipsec_dyn
crypto map site_monitor_tunnel 12 ipsec-isakmp
 set peer gg.gg.gg.gg
 set transform-set default_windows
 match address local_to_wilmottechnologies
crypto map site_monitor_tunnel 14 ipsec-isakmp dynamic ipsec_dyn
crypto map site_monitor_tunnel 1000 ipsec-isakmp dynamic L2TP_dm
interface Tunnel0
 no ip address
 shutdown
 ipv6 address 20d01:4470:1C:912::2/64
 ipv6 enable
 ipv6 traffic-filter publicRX in
 tunnel source ss.ss.ss.ss
 tunnel mode ipv6ip
 tunnel destination hh.hh.hh.hh
 no ip address
 no ip address
switchport mode access
no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
interface FastEthernet8
 ip address gg.gg.gg.gg ff.ff.ff.ff
 ip access-group wan-to-lan in
 ip nat outside
 ip inspect fw out
 shutdown
 duplex auto
 speed auto
interface Virtual-Template1
 ip unnumbered Vlan1300
 peer default ip address dhcp
 ppp authentication ms-chap-v2 vpdn_auth
interface GigabitEthernet0
 ip address 45.18.66.54 255.255.255.251
 ip nat outside
 duplex auto
 speed auto
interface Vlan1
 no ip address
 ipv6 nd ra suppress
interface Vlan1300
 ip address 192.168.20.8 255.255.255.0 secondary
 ip address 192.168.0.2 255.255.255.0
 ip nat inside
interface Vlan1303
 ip nat inside
interface Async1
 no ip address
 encapsulation slip
ip local pool l2tptest 192.168.22.127 192.168.22.132
ip forward-protocol nd
ip flow-export version 9
no ip http server
no ip http secure-server
ip dns view company.local
 no domain lookup
 dns forwarding
 dns forwarder 192.168.0.216
 dns forwarder 192.168.0.204
 dns forwarding source-interface Vlan1
ip dns view default
 dns forwarder 209.234.0.3
 dns forwarder 209.234.0.4
ip dns view-list view-default
 view anselmahouse.local 1
  restrict name-group 1
 view default 100
ip dns name-list 1 permit company.LOCAL
ip dns name-list 1 permit .*.company.LOCAL
ip dns server view-group view-default
ip dns server
ip nat inside source static tcp 192.168.0.204 1723 interface FastEthernet8 1723
ip nat inside source list 199 interface GigabitEthernet0 overload
ip nat inside source static tcp 192.168.0.212 2525 132.149.172.238 25 extendable
ip nat inside source static tcp 192.168.0.204 80 132.149.172.238 80 route-map nonat extendable
ip nat inside source static tcp 192.168.0.204 443 132.149.172.238 443 route-map nonat extendable
ip nat inside source static tcp 192.168.0.204 1688 132.149.172.238 1688 route-map nonat extendable
ip nat inside source static tcp 192.168.20.90 1911 132.149.172.238 1911 route-map nonat extendable
ip nat inside source static tcp 192.168.0.60 22 132.149.172.238 2201 route-map nonat extendable
ip nat inside source static tcp 192.168.20.90 3011 132.149.172.238 3011 route-map nonat extendable
ip nat inside source static tcp 192.168.20.90 8011 132.149.172.238 8011 route-map nonat extendable
ip nat inside source static tcp 192.168.0.221 3389 132.149.172.238 8903 route-map nonat extendable
ip nat inside source static tcp 192.168.0.204 3389 132.149.172.238 8904 route-map nonat extendable
ip nat inside source static tcp 192.168.0.220 3389 132.149.172.238 8908 route-map nonat extendable
ip nat inside source static tcp 192.168.0.222 3389 132.149.172.238 8909 route-map nonat extendable
ip route 0.0.0.0 0.0.0.0 72.139.72.37
ip route 172.164.44.0 255.255.255.0 192.168.0.8
ip route 192.168.16.0 255.255.255.0 192.168.0.8
ip route 192.168.18.0 255.255.255.0 192.168.0.8
ip route 192.168.99.0 255.255.255.0 192.168.0.8
ip access-list standard management4
 permit 192.168.0.0 0.0.255.255
 permit 10.0.0.0 0.255.255.255
 permit 172.0.0.0 0.240.255.255
 permit 172.142.50.0 0.0.0.255
ip access-list extended ipsec_dyn
 permit ip 192.168.0.0 0.0.0.255 172.16.8.0 0.0.0.255
ip access-list extended local_to_technologies
 permit ip 192.168.0.0 0.0.0.255 172.16.4.0 0.0.0.255
ip access-list extended nat_routemap_nonat
 deny   ip 192.168.0.0 0.0.0.255 172.16.3.0 0.0.0.255
 deny   ip 192.168.0.0 0.0.0.255 172.16.4.0 0.0.0.255
 deny   ip 172.16.4.0 0.0.0.255 172.16.9.0 0.0.0.255
 deny   ip 172.16.4.0 0.0.0.255 172.16.3.0 0.0.0.255
 permit ip 192.168.0.0 0.0.0.255 any
 permit ip 172.16.5.0 0.0.0.255 any
 permit ip any any
ip access-list extended wan-to-lan
 permit tcp any any range 8900 8909
 permit tcp any any range 2201 2209
 permit tcp any any eq 22
 permit tcp any any eq 443
 permit tcp any any eq 1723
 permit tcp any any eq www
 permit gre any any
 permit esp any any
 permit ahp any any
 permit tcp any any eq 8011
 permit tcp any any eq 1911
 permit tcp any any eq 3011
 permit tcp any any eq smtp
 permit udp any any eq non500-isakmp
 permit udp any any eq isakmp
 permit ip object-group level3.dns any
 permit icmp any any echo
 permit udp any any eq snmp
 permit tcp 72.148.61.0 0.0.0.255 any eq 1688
 permit tcp 205.124.127.0 0.0.0.255 any eq 1688
 permit tcp host 172.142.117.6 any eq 1688
 permit tcp host 64.39.171.21 any eq 1688
 permit tcp host 199.27.203.58 any eq 1688
 permit tcp host 199.235.216.22 any eq 1688
 permit tcp 198.143.185.167 0.0.0.7 any eq 1688
ip radius source-interface Vlan1
logging source-interface Vlan1
logging 192.168.0.216
logging 192.168.16.208
access-list 199 deny   ip any host 192.42.116.41 log
access-list 199 deny   ip any host 212.227.252.198 log
access-list 199 deny   ip 172.16.4.0 0.0.0.255 172.16.1.0 0.0.0.255
access-list 199 deny   ip 172.16.4.0 0.0.0.255 172.16.7.0 0.0.0.255
access-list 199 deny   ip 192.168.0.0 0.0.0.255 172.16.1.0 0.0.0.255
access-list 199 deny   ip 192.168.0.0 0.0.0.255 172.16.7.0 0.0.0.255
access-list 199 deny   ip 192.168.0.0 0.0.255.255 10.0.0.0 0.255.255.255
access-list 199 deny   tcp 192.168.0.0 0.0.255.255 any eq 57650 log
access-list 199 permit ip host 192.168.18.22 any
access-list 199 permit ip host 192.168.18.10 any
access-list 199 permit ip 192.168.0.0 0.0.0.255 any
access-list 199 permit ip 192.168.20.0 0.0.0.255 any
access-list 199 permit ip 192.168.99.0 0.0.0.255 any
access-list 199 permit ip 192.168.168.0 0.0.0.255 any
access-list 199 permit ip 173.160.4.0 0.0.0.255 any
no cdp run
ipv6 route ::/0 Tunnel0
route-map nonat permit 10
 match ip address nat_routemap_nonat
snmp-server community publicIPV6 RO ipv6 management
snmp-server community public RO management4
radius server auth04-1-1.company.local
 address ipv4 192.168.0.216 auth-port 1645 acct-port 1646
 key 7 08167C572E21303F2B3F
ipv6 access-list publicRX
 deny tcp any any eq 445
 deny tcp any any eq 137
 deny tcp any any eq 139
 deny udp any any eq netbios-ns
 deny udp any any eq netbios-dgm
 permit ipv6 any any
 permit icmp any any
ipv6 access-list management
 permit ipv6 2001:470:1D:90E::/64 any
 permit ipv6 2001:470:1D:90D::/64 any
 permit ipv6 2001:470:B2AA::/48 any
control-plane
mgcp profile default
line con 0
line 1
 modem InOut
 stopbits 1
 speed 115200
 flowcontrol hardware
line aux 0
line vty 0 4
 session-timeout 120  output
 exec-timeout 120 0
 transport input ssh
ntp source Vlan1
ntp peer 0.pool.ntp.org
end
Will you please post the "show ip dhcp conflict" command output.
Thanks & Regards,
Antonin
I tested your configuration in my lab and it is working fine:
 60 permit udp any any eq bootps (33 matches)
Please clear DHCP Binding, DHCP database from the router and check again. I hope this will clear your issues.
One more thing: Kindly confirm that there will no ACL, ARP spoofing, DHCP spoofing is configured on your switches.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Everyone,
I'm wonder if the ISR was in some loop, but I typed the show dhcp conflicts and there were quite a few of them, then I did the release of the dhcp bindings at which point I had no access to the ISR. I restarted the ISR by physically unplugging the power and back on. Then everything was working.
Thanks for everyone for your help on this. I'm not sure what exactly fixed the issue
Thanks for posting back and letting us know that you have solved your problem. +5 for that. The lesson that we can learn from this is that sometimes when we are looking at a problem and the config seems to be correct but the behavior is different that a reboot may get it working again.
Rick
Rick
