DHCP on Switch ?
Can we create DHCP Pool on a Layer 2 Switch?
5 Replies 5
royalblues
Level 10
Level 10
What is the model of the L2 switch you are using. I dont think it is supported on all the L2 switches. Recent ones like the 2960 do support this configuration
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_44_se/configuration/guide/swipaddr.html#wp1184895
Narayan
we have 2950 Switch
I am afraid, the 2950 does not support DHCP server configurations
Narayan
Thank's Mite
is there any Cisco Switch in market which will support DHCP server configuration.
best bet is to get hold of any L3 switch
3550, 3560 or the 3750
Narayan
