DHCP Pool error
eash
Level 2
Level 2
Dear All,
I have L3 switch configured as DHCP server for 5 pools. For one of the pools the the leased IP shows as 4294967275. The capture is enclosed.
Request you to kind support for this problem.
Eash
11 Replies 11
Peter Paluch
Eash,
There is a couple of things that surprise me in the snapshot you have posted:
  • The two DHCP pools displayed have the same name "DHCP21", just the one on the top of the screen has a strange "apostrophe" shown as as a tiny dot at the very top line below the terminal window header. Is that a JPG artifact, or do you really have two pools called DHCP21, or perhaps DHCP21-and-something?
  • The number of leased IP addresses is truly strange - in fact, it is the maximum number that can be expressed in an unsigned 4B integer variable, that is, 2^32 - 1. That could possibly indicate a software bug.
In any case, does the DHCP pool with the 192.168.210.0/24 network currently serve any addresses? If it does then this is some kind of a cosmetical bug - you should be able to report it to TAC but otherwise, I would not bother too much with it. To remove it, you could try removing the pool configuration completely, then putting it back. Beware, however, that this will also cause the DHCP server to possibly lose track of the leased addresses in that pool, so conflicts could ensue. Another take on this would be to reload the device - but this is a last resort suggestion.
Best regards,
Peter
Hi peter,
Thanks for the reply and sorry for the delay in responding.
The dhcp pool are 100 and 110.
The user in the VLAN 100 are getting their IP's from the dhcp pool 192,168.210.0/24. Few users are able to obtain the IP address. But I am worried it should not affect other VLAN and users.
Please find enclosed the capture of the sh ver and correct sh ip dhcp pool.
Rebooting the device is not possible as it working enviroment.
Any other suggestion is welcome.
Eash
Hi Eash,
Thank you for the additional info. Unfortunately, the data shown in the screenshots do not make any more sense to me than they do to you.
Is it possible to post the complete configuration of the switch please? Of course remove sensitive information such as passwords etc. If that is not permissible, can you at least post the configuration of all DHCP pools and excluded ranges? I am grasping at straws here, as the show command outputs are simply illogical.
Thanks!
Best regards,
Peter
Hi Peter,
Please find the DHCP config enclosed.
ip dhcp remember
ip dhcp conflict resolution
ip dhcp excluded-address 192.168.210.1 192.168.210.31
ip dhcp excluded-address 192.168.210.160 192.168.210.254
ip dhcp excluded-address 192.168.211.1 192.168.211.31
ip dhcp excluded-address 192.168.211.160 192.168.211.254
ip dhcp excluded-address 192.168.212.1 192.168.212.31
ip dhcp excluded-address 192.168.212.160 192.168.212.254
ip dhcp excluded-address 192.168.213.1 192.168.213.31
ip dhcp excluded-address 192.168.213.160 192.168.213.254
ip dhcp excluded-address 192.168.214.1 192.168.214.31
ip dhcp excluded-address 192.168.214.160 192.168.214.254
ip dhcp excluded-address 192.168.209.1 192.168.209.31
ip dhcp excluded-address 192.168.209.160 192.168.209.254
ip dhcp pool DHCP210
   network 192.168.210.0 255.255.255.0
   default-router 192.168.210.200
   dns-server 192.168.200.199
ip dhcp pool DHCP211
   network 192.168.211.0 255.255.255.0
   default-router 192.168.211.200
ip dhcp pool DHCP212
   network 192.168.212.0 255.255.255.0
   default-router 192.168.212.200
ip dhcp pool DHCP213
   network 192.168.213.0 255.255.255.0
   default-router 192.168.213.200
ip dhcp pool DHCP214
   network 192.168.214.0 255.255.255.0
   default-router 192.168.214.200
ip dhcp pool DHCP209
   network 192.168.209.0 255.255.255.0
   default-router 192.168.209.200
ip dhcp pool dhcp210
   lease 48
ip dhcp pool dhcp211
   lease 48
ip dhcp pool dhcp212
   lease 48
ip dhcp pool dhcp213
   lease 48
ip dhcp pool dhcp214
   lease 48
Please do let me know if some more information is required.
Eash
Could just be an odd anomaly.
I would either delete and recreate the pool or reboot the switch.
Dear Peter,
I made the changes as suggested. I moved the lease to uppercased dhcp pool and removed the lowercased ones.
My question inspite of it the lease ip address did not change and the exclude ip address shown is wrong.
Please see the below changes
router#ip dhcp remember
   dns-server 172.16.141.13
   lease 2
   lease 2
   lease 2
   domain-name exedy.co.jp
   lease 2
   lease 2
   lease 2
router#sh ip dhcp pool
Pool DHCP210 :
 Utilization mark (high/low)    : 100 / 0
 Subnet size (first/next)       : 0 / 0
 Total addresses                : 254
 Leased addresses               : 4294967248
 Excluded addresses             : 163
 Remembered addresses           : 2
 Pending event                  : none
 1 subnet is currently in the pool :
 Current index        IP address range                    Leased/Excluded/Total
 192.168.210.50       192.168.210.1    - 192.168.210.254   4294967248 / 163   / 254
Pool DHCP211 :
 Leased addresses               : 0
 Excluded addresses             : 128
 Remembered addresses           : 16
 192.168.211.87       192.168.211.1    - 192.168.211.254   0     / 128   / 254
Pool DHCP212 :
 Leased addresses               : 2
 Remembered addresses           : 29
 192.168.212.70       192.168.212.1    - 192.168.212.254   2     / 128   / 254
Pool DHCP213 :
 Excluded addresses             : 126
 192.168.213.65       192.168.213.1    - 192.168.213.254   0     / 126   / 254
Pool DHCP214 :
 Remembered addresses           : 0
 192.168.214.1        192.168.214.1    - 192.168.214.254   0     / 126   / 254
Pool DHCP209 :
 192.168.209.34       192.168.209.1    - 192.168.209.254   0     / 126   / 254
one more thing I get repeated dhcp-4_ping_conflict messages.
Request you suggestion.
Eash
Hi peter,
As per your suggestion,
After removing all  the duplicate DHCP pools in  lowercase and enabling no ip dhcp logging the problem of clients not able to get IP address from DHCP got resolved to some extend.
But when I observed in the VLAN 210 after leased IP touches 110 no new clients are able to obtain IP address. Although the pool has 128 ip's address to lease.
Please let me know if there is any problem in my above DHCP configuration and when I issue clear ip dhcp binding * to reset and the sh ip dhcp pool of vlan 210 starts showing the weird leased ip's as below,
Pool DHCP210 :
could adding ip helper-address in my L2 switch be of any help.
My network is follows,
Core (3750) === L2 (2960)== clients for each of the VLAN's.
Request your helpful inputs. This problem is really bugging me.
Eash
Pool DHCP210 :
Hi You have excluded 163. So leave you only atmost 254-163 around 90.
Hi Raksha,
The problem that I am facing is, in the VLAN 210 after leased IP touches 110 no new clients are able to obtain IP address from the DHCP. Although the pool has 128 IP's address to lease and the number of IP's excluded is 126 as can be seen in the config show earlier.
When I issue clear ip dhcp binding * to reset after that when I check sh ip dhcp pool I observe for vlan 210 it is showing weird leased and excluded IP's as below,
Pool DHCP210 :
Request you valuable suggestion to resolve this problem.
Eash
Dear All,
Any thoughts of what could be causing this problem.
I need your support to emergency situation.
Eash
Eash,
I do not see anything suspicious except for one thing: You have two pools of the same name for each intended pool, one's name written out in uppercase, the other in lowercase. As the names of DHCP pools are case sensitive, you have in fact have two pools, one of them having all the addressing information, the second having only the lease time defined. I am sure this is not what you wanted.
Can you try correcting this by moving the lease 48 keyword to the uppercased DHCP pools, and then removing all duplicate DHCP pools having the lowercased name please? Perhaps this duplicity is what is confusing your IOS.
Best regards,
Peter
