DHCP pool excluding more addresses than are on the exclusion list
KJ-NYC
I have several DHCP servers configured on my 9300 switch stack, and they are all operating well. One of them has run out of IPs in its /22 DHCP pool due to an exclusion that I cannot get to the bottom of. It is excluding 337 IPs:
Pool WiFi :
 Utilization mark (high/low)    : 100 / 0
 Subnet size (first/next)       : 0 / 0
 Total addresses                : 1022
 Leased addresses               : 685
 Excluded addresses             : 337
 Pending event                  : none
 1 subnet is currently in the pool :
 Current index        IP address range                        Leased/Excluded/Total
 0.0.0.0              10.224.104.1     - 10.224.107.254    685   / 337   / 1022
but there are only 4 exclusions listed in the config:
#sho run | inc excluded
ip dhcp excluded-address 10.224.209.1 10.224.209.19
ip dhcp excluded-address 10.224.210.1 10.224.210.19
ip dhcp excluded-address 10.224.211.1 10.224.211.19
ip dhcp excluded-address 10.224.102.1 10.224.102.9
ip dhcp excluded-address 10.224.102.200 10.224.102.254
ip dhcp excluded-address 10.224.103.1 10.224.103.19
ip dhcp excluded-address 10.224.100.1 10.224.100.99
ip dhcp excluded-address 10.224.110.2 10.224.110.10
ip dhcp excluded-address 10.224.104.1 10.224.104.4
 What would be causing this exclusion if it is not explicitly listed?
KJ-NYC
Thanks for the quick responses, guys. We were able to figure it out. It turns out that when the DHCP server sees an IP conflict, it adds the conflicting IPs to the exclusion list, and they stay there until explicitly removed. We were able to clear the list with the
clear ip dhcp conflict *
 command, and voila! the exclusion list matched the config exclusion number.
5 Replies 5
What is the mask for this dhcp pool?
MHM
Richard Burts
Not sure what is causing this. Could you post the complete current running config, obscuring any sensitive information (passwords, Public addresses, etc).
Rick
KJ-NYC
And after some time the conflict table full again.
There is issue friend
Anyway if it appear again let me ķnow
MHM
Thanks for the update. Glad that you were able to resolve the issue.
Rick
