DHCP Relay Help
mconway
I would like to use the ip address-helper feature of my 3560 switch to point 10.1.0.0/24 to my Windows DHCP Server on 10.0.0.0/24 and I am unsure how to go about doing this.
Below is a diagram of the network.
Jeff Van Houten
Level 5
Level 5
on the svi for 10.1.0.0/24, add ip helper-address (host address of dhcp server)
darren.g
Level 5
Level 5
Use the IP helper command on the SVI for VLAN 20
#configure terminal
(configure)#interface vlan20
(configure-if)#ip helper-address 10.0.0.245
(configure-if)#exit
(configure)#exit
copy run start
Of course, you then need to configure an additional scope in the Windows DHCP server to allocate for the 10.1.0.0/24 subnet, with appropriate options.
Cheers
