DHCP relay issue with Nexus 3K
elie_ibrahim34
Hello all,
I have a strange issue with some Cisco IP Phones.
Recently we installed a couple of Nexus 3548 in our network, they are configured with vPC and HSRP, there are 2 catalyst 9300's for distribution connected via port-channel to the Nexuses.The problematic phones are plugged into an access switch connected to the distribution switch.
The problem i have is that my phones are not getting dhcp addresses from our server on a different subnet.
I have the dhcp feature enabled and configured the ip dhcp relay address under all my SVI's.
A wireshark capture shows the DHCP Discover transaction as being a broaddcast. Correct me if im wrong, but this should be a unicast request?
I have built a test vm that i placed in the same vlan as my phones, and i do get an IP via DHCP.
Any ideas? Your help is greatly appreciated!
2 Accepted Solutions
Working on this with TAC
Closing this thread
Upgrade to 9.2.2 . This worked for me
19 Replies 19
the phones need option 82, do you have that configured globally with the  'ip dhcp relay information option' command ?
Hi Georg,
Yes i have it configured
Also when i issue the command show ip dhcp relay, i see
sh ip dhcp relay
DHCP relay service is enabled
Insertion of option 82 is enabled
Insertion of option 82 customize circuitid is disabled
Insertion of VPN suboptions is disabled
Insertion of cisco suboptions is disabled
Global smart-relay is disabled
Relay Trusted functionality is disabled
Relay Trusted Port is Globally disabled
V4 Relay Source Address HSRP is Globally disabled
Thanks for your help
Try to enable the cisco sub-option:
ip dhcp relay sub-option type cisco
I just did, however still no success
The wireshark capture still shows DHCP Discover and DHCP Offer, both are broadcasts...
Successfull dhcp requests shows the DHCP Discover and Offer as Unicast in the BootP protocol
Also, i have other phones connected to the same switch that are functionnal
odd indeed. I assume the hosts are actually in a different subnet than the relay server ?
Could be a bug, which version are you running ?
Yes indeed the hosts are on vlan 33 and the dhcp server is on vlan 32.
The version im running on the nexus is  NXOS: version 7.0(3)I7(3)
I'll check for bugs. In the meantime, if possible, try and reload the switch...that sometimes helps...
Thanks for the help, rebooting the switch is a must, i'll have to schedule a window
I will report back if that fixes the issue
I confirm rebooting the switch did NOT solve this issue.
In fact it made matters worse, no IP Phone connected to that access switch is now getting and IP from the DHCP
Thanks for any input!
you have more of the 3548 switches, do any of the other ones have the same problem ?
No these are the only 3548's we have at this site.
This issue only seems to be impacting Cisco IP Phone for some reason
can you post the config of one of the switches ? I just want to check how your voice vlan is configured...
Below is the config for the SVI for the voice vlan of the active router in the hsrp config, ip's are changed for our purposes
interface Vlan33
no shutdown
no ip redirects
ip address 192.168.33.2/24
no ipv6 redirects
hsrp 33
preempt delay minimum 300
priority 130
ip 192.168.33.1
ip dhcp relay address 192.168.32.223
Interesting to note that a vm placed in that same subnet is able to get an IP from the DHCP.
Also the dhcp scope includes option 150 pointing towards the TFTP server for Cisco Phones
on the older IOS switches you could tie the IP helper addresses to redundancy groups, thus avoiding the broadcasts being converted and sent from both the active and the standby switch. There doesn't seem to be that option in NX-OS. That said, is it possible for testing purposes to disable the HSRP and check if that makes a difference ?
