DHCP server and router-on-a-stick are diff devices for dhcp client
chch6597
Hello all,
I have been struggling with a problem I kind of create myself, or my knowledge is still not good enough, hopefully some professionals can help me. Look at my picture:
My PC wants to get IP address from DHCP server, but they are in different vlan so I put a router on a stick with sub-interfaces .10 with 192.168.10.254 and .20 with 192.168.20.254, but my PC doesn't get IP address. I also configured default route on PC and DHCP server that points to the Router. I did some research and people suggest to do ip helper-address on Router or Switch, but I tried both, it's still not working. I can see my DHCP server can get DHCP discover but that's it. Am I missing anything? or this is impossible?
Thank you for your answers
I kind of figure it out. Instead of the command, 'network 192.168.20.0 255.255.255.0', I put 'network 192.168.10.0 255.255.255.0', I'm not really sure why, but my best guess is the sub-interface of Router is 192.168.10.254 so it will give out the same subnet from the vlan 10
luis_cordova
Hi @chch6597 ,
Your configurations should be something like this:
Switch L3:
g0/0
switchport mode access
switchport access valn 10
g0/2
switchport access valn 20
g0/1
switchport mode trunk
Router
f0/0
no ip address
f0/0.10
ip address 192.168.10.254
ip helper-address <ip dhcp server>
f0/0.20
ip address 192.168.20.254
@luis_cordova
Thank you for your reply! That's what I have right now but my DHCP server can only get DHCP DISCOVER message. That's it. I wonder if I missed anything else
can you ping PC<---->DHCP ?
