IE3000 keep rebooting
TofiJa1652410
Hi there, I have switch 3000, and it's on a continues reboot loop. The attached file contains the data I managed to extract from it. PLZ, any help to identify the problem?
balaji.bandi
Below information indicates hardware failed. ( if you have contract Raise an TAC case for RMA).
supervisor subsystem initialization failed
xmen2_alloc_ptp_entry: PTP TCAM allocation failed.
driver class subsystem initialization failed
cisco IE-3000-8TC (PowerPC405) processor (revision H0) with 131072K bytes of memory.
Processor board ID FOC1648V1QH
Last reset from power-on
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 24:01:C7:D7:29:00
Motherboard assembly number : 73-10855-12
Motherboard serial number : FOC16474GTH
Model revision number : H0
Motherboard revision number : A0
Model number : IE-3000-8TC
System serial number : FOC1648V1QH
Top Assembly Part Number : 800-28538-02
Top Assembly Revision Number : K0
Version ID : V02
CLEI Code Number : CMMFE00ARA
Hardware Board Revision Number : 0x02
!!! WARNING: The switch is not usable !!!
BB
Thanks for your answer, I don't have a contract on it TT
