DHCP server does not give out IP:s
Greg555
Im new to cisco packet tracer, and I have a one question.
Why does not my server give out DHCP adresses to the different networks and what should I do to make it work?
On the router i have:5a48b8b63e353dbf706edb917443d7d2
cdfb975b2b9a67dbc6861360005169a8
/Greg
you need to make a few changes (additions are in bold):
Router1
interface FastEthernet0/0
ip address 192.168.65.1 255.255.255.0
ip helper-address 192.168.100.2
duplex auto
speed auto
Router8
interface FastEthernet1/0
ip address 192.168.55.1 255.255.255.0
duplex auto
speed auto
Switch3
interface FastEthernet0/1
switchport mode access
interface FastEthernet4/1
On the DHCP server, Server1, you have the wrong default gateway, it is currently set to 192.168.100.2 and needs to be 192.168.100.1.
6 Replies 6
Mark Elsen
 - For starters, DHCP is a layer 2 protocol. If it needs to serve different networks, you usually need to specify a helper address pointing to the DHCP server  at the default gateway for those networks.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Post your Packet Tracer project file (zip it first otherwise you cannot upload)...
Here it is!
Router1
duplex auto
speed auto
Router8
duplex auto
speed auto
Switch3
Thank you so much, it worked! Now all the PC:s can request dhcp adress.
However, I can't ping the wireless ones with the wired ones :/
your Router8 is missing the static route below:
ip route 192.168.65.0 255.255.255.0 192.168.50.1
