DHCP server per VRF Cisco switch
yappsyduck
I have DCHP server configured on Cisco 6506-E switch with supervision module VS-SUP2T-10G. It will only provide DHCP to the clients in the specified VRF. I had do some research at the forum and found that below config need to add as part of work around for this. But unluckily the highlight command was not allow to configure in the switch.The running IOS version is s2t54-adventerprisek9_npe-mz.SPA.150-1.SY2.bin. Is it the IOS not support DHCP per VRF?Anyone was facing this issue before? thanks.
vrf example
rd 100:0
ip dhcp use vrf connected
ip dhcp pool pool1
network 192.168.1.0 255.255.255.0
default-router 192.168.2.5
dns-server 4.2.2.2
vrf example
thanks
Cguy
6 Replies 6
Reza Sharifi
ip dhcp use vrf connected is not supported on IOS versions for the 6500 or 6800 series.
Hi Reza
Thanks on  your  prompt  reply. Since it is not support, do you have any idea to achieve the DHCP per VRF in Cisco 6500 or 6800 series?
thanks
Cguy
Hi Cguy,
You are trying to use "DHCP pool" per vrf is that right?
If yes, I am not sure if there is way to do this on the 6500.
One way to do this is not to use the switch as DHCP server and use an external device (server) as a DHCP server and just add helper address  to the vlan to point to the external server.
(ip helper address <server ip>)
and also add the SVI for that vlan to a vrf.
Hi Reza
Yes, I am trying to use DHCP pool per vrf  in switch. Thanks on your suggestion.
BR
Cguy
Can you show us the multiple DHCP pool/network statements for each of the VLAN's?
Remember each vrf needs its own DHCP pool definition and parameters.  Only those with matching information are going to get DHCP leases.
hi pwwiddicombe,
The dhcp pool and vlan interface configuration as below. But the vrf clients not able to get DHCP lease.
vrf test1
rd 100:0
ip dhcp pool test1
default-router 192.168.1.1
dns-server 4.2.2.2
interface vlan 100
ip vrf forwarding test1
