Filtering authentication messages on switches
Jimothy007
I want to reduce the amount of syslog messages going to a syslog server for 802.1x, MAB and authentication messages from our switches and have seen the commands:
no authentication logging verbose
no dot1x logging verbose
no mab logging verbose.
I've searched everywhere and the explanantion is that they filter out the respective verbose system messages "typically relating to authenication success". I was hoping to find out exactly what they filter out, e.g. a list, but haven't been able to find that anywhere.
I understand what the bottom two lines will do but not the top line. Does anyone know wehre I could find that information?
Also, it's probably not the right forum but where on earth can I find how to do this also on a HP switch!
Jimothy007
I see what you mean, I suppose the only thing to do is see the difference in the system log with and without verbose logging
Use the no authentication logging verbose global configuration command on the switch stack or on a standalone switch to filter detailed information from authentication system messages.
Defaults
All details are displayed in the system messages.
Syntax Description
This command has no arguments or keywords.
Command Modes
Global configuration
Command History
Release
Modification
12.2(55)SE
This command was introduced.
Usage Guidelines
This command filters details, such as anticipated success, from authentication system messages.
Examples
To filter verbose authentication system messages:
Switch(config)# no authentication logging verbose
Richard, Yeah, weird there is no detailed description, will just have to apply it and see what it does if I go this way. Jim
Mark Malone
Hi just an option may work you try could use logging discriminator block them going to syslog, you can filter by msg body type that gets sent out to syslog
http://www.cisco.com/c/en/us/td/docs/ios/12_4t/12_4t11/htnmsylg.html
Thanks Mark, I'll look into that one, could be another option.
Jim
