DHCP_SNOOPING_DENY
Ivan Marinovic
Good morning,
I have one small problem...
When i change voice vlan on one location I start receiving this massage:
%SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Req) on Fa0/11, vlan 8.([e8ba.7006.b8aa/10.15.8.2/0000.0000.0000/10.15.8.1/21:52:59 C
And phones are not working any more…
loong description:
In one of our location we don’t have distribution switch, (because it is small-only 20 users), so we connect cisco 2960 directly to 6509. So our core switch is also distribution switch for that location.
Currently we are using 2 vlan  10 for voice and  20 for data. Now i need to change voice vlan to vlan 8. When i change/create new vlan, add new interface, add trunk… and on 2960 change switchport voice vlan. Ip phones (cisco and linksys) are not booting, they don’t receive dhcp. And in log i find these massage:
So what command i need to enter that switch „trust“ that phones??
I try clear all mac, arp tables but that didn’t help.
Talha Ansari
It would be helpful if you post the configuration of 2960 and 6500.
I think you have DHCP and Dynamic Arp Inspection enabled right on 6500.
Try this :
1) Clear DHCP bindings on the DHCP server.
2) Change the Voice VLAN.
3) Clear ARP on 6500.
Talha
5 Replies 5
Talha Ansari
Try this :
Talha
Thanks on your replay...
i will try this tonight when no users are log on....
config  2960
You have DHCP snooping and DAI configured indeed:
ip dhcp snooping vlan 2-95
ip dhcp snooping
ip name-server
ip arp inspection vlan 2-95
So do like Talha said and also clear the ip dhcp snooping binding database:
clear ip dhcp snooping database
Regards.
Alain.
I did as Talha sad:
but it was not working so i did:
no ip dhcp snooping vlan 2-95
no ip dhcp snooping
no ip name-server
no ip arp inspection vlan 2-95
and then everything go ok... and then I enable privies command....
Thanx,
Ivan
Using the no commands was the shortest cut..
Nice to know it ended well.
