DHCP snooping miltiple switches AP authonomous
rparrat666
I have a problema with DHCP. I have two 2960 connected with a port channel on ports 47 and 48 as trunk with native vlan 10. I only have this one vlan. In port 1 of sw 1, I have a C800 as DHCP server.
I have an AP autonomous witrh single ssid on vlan 10.
When I connect the AP to sw1, I receive dhcp with no problems.
When I connect the AP to sw 2, I’m not getting IP by DHCP.
I have DHCP snooping working on vlan 10 on both devices.
The ports where I connect the AP are access ports on vlan 10 config as trusted.
The trunk ports are also configured as trusted.
The port 1 of ws 1 that goes to the C800 is also configured as trusted.
I need some help to figure out why I’m not getting IP by DHCP when I connect the AP to the SW 2.
The only I notice is that when I connect the AP to sw 2, I get on SW 1 the message of packet drop by option 82, but even after configuring ip dhcp snooping information option allow-untrusted on both switches, the problem persists.
thanks
5 Replies 5
Hello
Do you have connecrivity from this port?
Can you receive an ip address from dhcp if you plug a pc into it? - Have you tried static addressing ?
On switch 2 have you defined L2 vlan for vlan 10?
res
Paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Vlan 10 is configured as access on all ports, and is passing tru the tunk port.
If I’m connected tp the sw 2 with a wired, I get IP by DHCP without any problem and have full connectivity.
If I configure a static ip address on my wireless interface, I have full connectivity tru the SSID.
Hello
Can you post the config of the wlan ap
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
! Last configuration change at 18:10:56 GMT Sun Feb 28 1993 by admin
version 15.2
no service pad
service password-encryption
hostname AP
logging rate-limit console 9
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone GMT -6 0
ip cef
ip dhcp-server 10.69.32.1
dot11 syslog
dot11 ssid xtndsyses
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 03227D2D202A04696B2D3D213330292E260B0A05096365
dot11 network-map
username --- privilege 15 secret 5
bridge irb
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
ssid xtndsyses
antenna gain 0
stbc
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
ssid ssidap
antenna gain 0
dfs band 3 block
stbc
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.69.32.7 255.255.255.0
ip helper-address 10.69.32.1
ip default-gateway 10.69.32.1
ip forward-protocol nd
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip route 0.0.0.0 0.0.0.0 10.69.32.1
snmp-server community ro RO
snmp-server community rw RW
bridge 1 route ip
line con 0
line vty 0 4
transport input all
end
Are you trying to obtain dhcp for clients connecting to this AP or for the AP to obtain a dynamic ip address?
Thanks.
Kind Regards
Paul
