dhcp trust to prevent rogue dhcp device on Access switches
tlebouef
I am trying to prevent rogue dhcp request from bringing down my network.
My dhcp servers are not local to the network
But helpers/proxy over the firewalls and local core to a real dhcp servers at our data center.
Core is layer three ... dhcp servers are over the wan ... interconnect to the core is lacp channel groups over fiber.
So 3750x layer 2 access switches to 4507 core layer three switches wan routers are asr1002's
Has anyone done this and can give me a real life example of the entire configuration ?
Ich Nafi
This is how we did it:
On the access switches:
Enable ip dhcp snooping on the VLAN you want to snoop
Example:
ip dhcp snooping vlan 1-4094
no ip dhcp snooping information option
ip dhcp snooping
On switchport:
ip dhcp snooping limit rate 100
(values lower than 100 can make your switchport go to errdisable. Windows can go pretty crazy on DHCP requests)
On uplink port do Distri/Core (if Layer 2 Trunk-Port):
ip dhcp snooping trust
If you do ip arp inspection you also want to tell the switch to save the snooping database on flash (in other case you'll lock out everyone after a switch reboot)
ip dhcp snooping database flash:dhcp
I think that's it.
