Bookmark
Subscribe
6029
Diagnostic Monitoring Data is not available
pbailey4
SUP720-3BXL
IOS 12.2(33)SXH2a
when i do a show int tranceiver details i get the "Diagnostic Monitor Data is not available" Is there something that I need to turn on?
Mark Yeates
Level 7
Level 7
Which transceivers are you using? If I remember correctly it will only show transceivers that have digital optical monitoring (DOM) enabled. This means that you have to have transceivers that support the DOM capability to use the "show interface tranceiver" command.
HTH,
Mark
SFP type. I am not sure the exact model as they are whatever shipped from cisco. I will physically check
GLC-SX-MM
