Dialers with HSRP
tonyk0001
Hi Team,   I hope this finds you well. I need some help, We have configured HSRP on WAN Routers but they all have dialers on them.   But when we trigger the fail over to the standby Router, The dialers don't come I think its because the tracking line protocol on the interfaces.   Please advise if there is something I can change.
Tony Karera
post the configs of your WAN routers so we can check and possible lab...
Hi George,
interface GigabitEthernet0/0/0.2
 encapsulation dot1Q 2
 ip address 105.179.2.2 255.255.255.252
interface GigabitEthernet0/0/0.4
 encapsulation dot1Q 4
 ip address 10.42.1.20 255.255.255.0
 ip nat outside
interface GigabitEthernet0/0/0.8
 encapsulation dot1Q 8
interface GigabitEthernet0/0/0.9
 description JJJJ
 encapsulation dot1Q 9
 ip access-group 110 in
 ip access-group 110 out
 pppoe enable group global
 pppoe-client dial-pool-number 3
interface GigabitEthernet0/0/0.12
 description PPP
 encapsulation dot1Q 12
 no ip redirects
 no ip proxy-arp
 pppoe-client dial-pool-number 1
interface GigabitEthernet0/0/0.13
 description BBB
 encapsulation dot1Q 13
 ip nat outside
 pppoe-client dial-pool-number 2
 ip virtual-reassembly
 --More--         !
interface GigabitEthernet0/0/0.213
 description VPN
 encapsulation dot1Q 213
 ip address 192.168.213.1 255.255.255.0
interface GigabitEthernet0/0/0.247
interface GigabitEthernet0/0/0.2039
 encapsulation dot1Q 2039
 ip address 192.168.26.1 255.255.255.0
interface GigabitEthernet0/0/0.2087
 encapsulation dot1Q 2087
ip address 192.168.90.2 255.255.255.0
interface GigabitEthernet0/0/1
 ip address 192.168.50.2 255.255.255.0
 negotiation auto
interface GigabitEthernet0/0/2
 ip address 192.168.20.2 255.255.255.0
 ip nat outside
 negotiation auto
 crypto map dcp
interface GigabitEthernet0/0/3
 ip address 172.16.20.3 255.255.255.240
 ip nat inside
 standby 1 ip 172.16.20.4
 standby 1 priority 150
 standby 1 preempt
 standby 1 track 1 decrement 55
 negotiation auto
ip address 192.168.10.2 255.255.255.0
 negotiation auto
interface Vlan1
 no ip address
 shutdown
interface Dialer1
 bandwidth 100000
 bandwidth inherit 100000
 ip address negotiated
 ip mtu 1492
 ip nat inside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication pap callin
 ppp pap sent-username x.x.x.x password 7 x.x.x.x
interface Dialer2
 ip mtu 1492
 --More--          ip nat outside
 encapsulation ppp
 dialer pool 2
 dialer-group 2
 ppp pap sent-username x.x.x. password 7 0x.x.x
 no cdp enable
interface Dialer3
 bandwidth 100000
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 dialer pool 3
 dialer-group 3
 ppp pap sent-username x.x.x. password 0 x.x.x
 --More--          ip virtual-reassembly
track 1 interface GigabitEthernet0/0/0 line-protocol
the dialer interface stays up even when the physical interface is down, that might indeed be the problem.
Try a boolean, where both the physical and the dialer interface is being tracked, if either one is down, the tracked object is considered down:
track 2 interface Dialer1 line-protocol
track 3 list boolean and
object 1
object 2
