DIFERENCIA ENTRE C1000-48FP-4G-L Y C1000-48P-4G-L
masgroupca
CUAL ES LA DIFERENCIA ENTRE LOS SWITCHES MODELO 1000-48FP-4G-L Y LOS MODELO C1000-48P-4G-L?
En el brochure dice q ambos equipos tienen 48 puertos con capacidad POE, sin embargo, en otras fuentes, dice que el modelo 48P , solo tiene 24 (de los 48 puertos con los que viene) con POE , y los otros 24 no.
Igualmente, hay modelos que indican 4X, en lugar de 4G
Gracias
as i clarified, all the ports in the 48 ports can be used for PoE, subject to power availability,
example - if the document mentioned  370W / 15W (device) - you can only add maximum 24 devices to that switch
if it is 750W / 15W = 48 ports can be used for PoE
hope this helps you ( as example)
BB
8 Replies 8
balaji.bandi
C1000-48P-4G-L
48x 10/100/1000 Ethernet PoE+ and 370W PoE budget ports, 4x 1G SFP uplinks
C1000-48FP-4G-L
48x 10/100/1000 Ethernet PoE+ ports and 740W PoE budget, 4x 1G SFP uplinks
because of the PSU
BB
OK. But both switches brings POE on the 48 ports?
According to some sources in other web sites, C1000-48P-4G-L only brings
POE to 24 ports, not to the 48, being the model 48FP the only to bring POE
to the 48 ports.
Even mention FP as "Full POE"...
Is that's true?
It all depends on PSU capacity more PSU means more POE.
BB
Yes. Of course more PSU means more POE-
But why other web sites as :
https://www.shi.com/shop/search/hardware/networking-and-security/hubs-and-switches?k=C1000-48P-4G-L&sk=1&h=1
or
https://4startech.com/c1000-48p-4g-l-cisco-catalyst-1000-switch-48-ports-poe-370w-new/
describes the the 48P as : Ports 24 x 10/100/1000 (PoE+) + 24 x 10/100/1000
and the 48FP as :Ports 48 x 10/100/1000 (PoE+) ??
Hence my confusion. The difference in price is notable and that's the
reason because I am creating this query .
Thank you very much in advance
always refer cisco product guide,
BB
I simply need to be sure , my dear friend, if both switches brings POE to
the 48 ports
BB
masgroupca
thank you very much . Now it is completely clarified !
