difference between 2248TP and 2248TPE
robertkwild
hi all,
just want to know the difference between the 2248TP and the 2248TP-E
https://www.cisco.com/c/en/us/products/switches/nexus-2000-series-fabric-extenders/models-comparison.html#~tab-1ge
the only difference i see are the buffers, what do they do and do i need the extra buffer space
thanks,
rob
Torbjørn
The only difference is buffer depth. Deep buffers allows your network to handle larger spikes of network traffic without traffic loss, at the potential cost of increased latency.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
would you say 8Mb is enough ?
