Difference between Gbps & Mpps
Sam Pragash
Level 2
Level 2
I am planning to replace a Cisco 3750E-24TD with Cisco 2960G-24TC.I wanted to make sure that 2960 will handle the load. When I went through the datasheets, I got the below queries.
What is the difference between Forwarding Bandwidth & Forwarding rate? Why they are mentioned in Gbps and sometimes in Mpps?
For Eg:
Cisco 3750E-24TD - 65.5 Mpps and
Cisco 2960G-24TC - 32 Gbps.
9 Replies 9
Hi Sam,
Gbps - Giga bit per second (how many bits can be processed by the device)
Mpps - Maximum packets per second (how many packets can be processed by the device)
For Mpps is depending the size of the packet transmited.
Eg: you send the smallest frame in ethernet which are 64 bytes in size+ interframe gap, so to fill a GE port in one direction you need 10^9 / [(64+20,2)*8] = 1484560 packets per second.
so a number around of 3  Mpps(1,48*2= 2,96 ) is equivalent to 1 GE ports filled with smallest frames bidirectional.
I hope this explanation will help
Forwarding bandwidth and forwarding rate measure different aspects of a switch’s capacity: forwarding bandwidth (Gbps) is the total data throughput the switch can handle per second, while forwarding rate (Mpps) measures how many packets per second it can process, usually based on the smallest packet size. A switch might have high bandwidth but a lower packet rate, meaning it could struggle with many small packets, or vice versa. In your example, the 3750E’s 65.5 Mpps indicates it can handle a high packet load efficiently, whereas the 2960G’s 32 Gbps shows total throughput but doesn’t guarantee the same performance with small, packet-heavy traffic, so the 2960G may not handle the same load as effectively.
Belated response. . .
The vice versa case would be unusual.
As described, as above, you cannot draw those conclusions for either the 3750E nor the 2960G.
For either switch you need to know BOTH its fabric's BPS capacity, its forwarding PPS (ideally for any packet size, but a minimum packet size rating may be, alone, sufficient) AND number of ports and their maximum bandwidth settings.
Additionally, there are other switch attributes that may dramatically impact its real-world performance, such as interface buffering capacity, architecture that avoids/precludes head-of-line blocking, and other features, especially if switch is a L3 switch.
For example, I recall the 3750E and its contemporary 4948 both had 48 copper gig ports, and fabric BPS and PPS forwarding to support all 48 ports, at wire speed, concurrently.  But they had some other major differences, and the 4948 was also considerably more expensive.  So, even BPS and PPS, as important as they often are, alone, may not be the crucial attributes for selection of the "best" switch.
Alessio Andreoli
Level 11
Level 11
Hi all,
I am sorry but I respectfully disagree with the Gbps and Mpps definitions provided above. The M of Mpps stands for Mega(million) packet per second and it is the way to size the processing capabilities of a determined platform. Generally the packet processed are set to the minimum size to provide the max overload to the CPU to analyse. Gbps instead literally means one billion(giga) of bit per second and it is the max capability of a determined link/interface. Generally speaking this capability will be never used due to the transceiver buffers and design. It is not unusual to test a gigabit link(or interface) with a multisession ds/us.
Hope this helps
Alessio
Hi Alessio,
You are right MPPS = million packets per second
Thanks!
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
They measure two different properties.  The Gbps rating is usually the fabric/bus bandwidth, shared by all port.  Normally, it quoted for duplex bandwidth.  For example, 24 Gbps (duplex) ports would require 48 Gbps of fabric bandwidth.  As the 2960G is listed as having only 32 Gbps, the switch can not support concurrent full capacity across 24 gig ports.
PPS measures, packets per second.  Requirement varys (greatly) on packet size. 1 Gbps Ethernet requires 1.488 Mpps.  As 24 gig (duplex) ports are only switched once, Ethernet wire-rate would require 24 * 1.488 Mpps = (about) 36 Mpps.  If the switch provides a lower Mpps rating, it might not be able to support concurrent full capacity across all its ports.  Of course, if bandwidth is restricted by fabric capacity, you might check whether it could support it's full capacity.  Also, again, PPS varies (much) on packet size.  A switch that might not guarantee wire-rate for worst case might deliver wire-rate for "normal" traffic.
PS:
When looking at switches, don't forget special uplink ports, like dual 10G ports that can be found on 3750Es.
. . . Mpps measures the number of data packets processed or transmitted per second in millions, which reflects how efficiently a device like a router, switch, or firewall can handle packet processing.
Although, certainly, efficiency can impact performance, increased PPS might be due to just doing whatever faster.
A simplistic example.  Say you have a automobile that can run down the road at 30 MPH @2,000 RPM, while obtaining 25 MPG.  If you double the RPM to 4,000, speed would likely increase to 60 MPH, but is this due to "efficiency" especially if MPG drops to 20?
Mpps, I would say, alone, doesn't indicate efficiency, however it combined with wattage, like PPS/Watt would indicate efficiency, yet a high efficiency doesn't often directly provide best performance; in fact the converse is often true.
Leo Laohoo
Uhhhhh ... wut?  WHY???
3750E-24TD is a multi-Layer switch (Layer 2/Layer 3) with 24 ports (non-PoE) capable of 10/100/1000 Mbps and an uplink capable of 10 Gbps.  The switch is capable of stacking.
A 2960G-24TC is a Layer 2 switch with 24 ports (non-PoE) capable of 10/100/1000 Mbps and an uplink of 1 Gbps (dual personality).  This switch is not able to stack.
@Leo Laohoo , did you miss OP dates?  (If so, something I too often miss.)
Your questions are valid, but according to OP user stats, OP hasn't logged into this site for many years, so an OP reply might not be forthcoming.
As to my recent replies, they were triggered by @asifarham383 's recent reply.
