Difference between ip verify source and ip verify source port security
mahesh18
Level 7
Level 7
Hi all,
We can enable ip source guard by command
ip source under  interface command.
but also we have command
ip verify  source  port-security  which we can also use under interface.
i have used both commands and here is output
3550SMIA#                                                   sh ip verify  source
Interface  Filter-type  Filter-mode  IP-address       Mac-address        Vlan
Fa0/15     ip-mac       active       192.168.20.18    permit-all         20
Fa0/20     ip           active       192.168.20.28                       20
Fa0/20     ip           active       192.168.20.62                       20
i need to know the difference between two commands   ip  verify source and ip  verify source port security
Also under filter type why we have ip-mac  and under mac address why it shows permit-all
thanks
mahesh
2 Accepted Solutions
Reza Sharifi
Mahesh,
"ip verify source" enable ip source guard with source IP filtering
and
ip verify source port-security enable ip source guard with source IP and MAC address filtering
Here is the link to the command reference guide:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_sea/command/reference/cli1.html#wp4288514
Reza
Hi Mahesh,
I see. Nevertheless, in DHCPv4, there is no message that could force a client to renew its DHCP lease. Thus, the only action we can trigger is a disconnect/reconnect event. Most DHCP clients will renew their lease as a result.
Best regards,
Peter
9 Replies 9
Reza Sharifi
Mahesh,
and
Reza
       Hi Reza
thanks for reply.
this is what i did
from gloabl config mode i run command
no ip dhcp snooping
then i enable it by
ip dhcp snooping
but now i see no dhcp snooping binding
Mar 12 14:01:09.900 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Req) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/0000.0000.0000/192.168.20.1/14:01:09 MST Sat Mar 12 2011])
Mar 12 14:01:10.900 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Req) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/0000.0000.0000/192.168.20.1/14:01:10 MST Sat Mar 12 2011])
Mar 12 14:01:33.905 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Res) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/f4ce.4667.9b45/192.168.20.28/14:01:33 MST Sat Mar 12 2011])
Mar 12 14:01:34.905 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Res) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/f4ce.4667.9b45/192.168.20.28/14:01:34 MST Sat Mar 12 2011])
Mar 12 14:01:34.905 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Req) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/0000.0000.0000/192.168.20.1/14:01:34 MST Sat Mar 12 2011])
Mar 12 14:01:35.905 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Res) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/f4ce.4667.9b45/192.168.20.28/14:01:35 MST Sat Mar 12 2011])
Mar 12 14:01:35.905 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Req) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/0000.0000.0000/192.168.20.1/14:01:35 MST Sat Mar 12 2011])
Mar 12 14:01:36.905 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Res) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/f4ce.4667.9b45/192.168.20.28/14:01:36 MST Sat Mar 12 2011])
Mar 12 14:01:37.905 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Res) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/f4ce.4667.9b45/192.168.20.28/14:01:37 MST Sat Mar 12 2011])
Mar 12 14:01:37.905 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Req) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/0000.0000.0000/192.168.20.1/14:01:37 MST Sat Mar 12 2011])
Mar 12 14:01:38.905 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Res) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/f4ce.4667.9b45/192.168.20.28/14:01:38 MST Sat Mar 12 2011])
Mar 12 14:01:38.905 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Req) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/0000.0000.0000/192.168.20.1/14:01:38 MST Sat Mar 12 2011])
Mar 12 14:01:39.905 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Req) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/0000.0000.0000/192.168.20.1/14:01:39 MST Sat Mar 12 2011])
Mar 12 14:01:40.905 MST: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Req) on Fa0/15, vlan 20.([0040.f418.6d8a/192.168.20.18/0000.0000.0000/192.168.20.1/14:01:40 MST Sat Mar 12 2011])
3550SMIA#                           sh ip dhcp sno
3550SMIA#                           sh ip dhcp snooping
Switch DHCP snooping is enabled
DHCP snooping is configured on following VLANs:
10,20,30,40
DHCP snooping is operational on following VLANs:
10,20,30,40
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is enabled
   circuit-id format: vlan-mod-port
    remote-id format: MAC
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface                    Trusted     Rate limit (pps)
FastEthernet0/8              yes         unlimited
3550SMIA#                           sh ip dhcp snooping  bin
3550SMIA#                           sh ip dhcp snooping  binding
MacAddress          IpAddress        Lease(sec)  Type           VLAN  Interface
Total number of bindings: 0
3550SMIA#sh ip verify source
Fa0/15     ip-mac       active       deny-all         permit-all         20
How can i see the entried in sh ip dhcp snooping binding again ?
thanks
Mahesh,
Your connected stations must renew their DHCP leases. As you have deactivated the DHCP Snooping, the database created from observing the DHCP messages was emptied. After you reactivate the snooping, the database must be populated again which will happen only by observing the DHCP messaging.
Best regards,
Peter
Hi Peter,
Thanks for reply.
How can from switch i can refesh their leases?
mahesh
Hi Mahesh,
The only way to force the stations to refresh their leases from a switch is to shutdown the corresponding ports, wait a certain time for the operating system on the stations to recognize that the connection is not valid (let's say a minute or so), and then reactivate the ports again. The stations will react as if they have been disconnected and reconnected to the network, and will reacquire their IP settings.
Apart from that, a switch cannot force a station to renegotiate its IP settings via DHCP.
Best regards,
Peter
Hi Peter,
LEt me give it shot.
will update you.
Hi Peter,
just let you know this 3550 switch is acting as dhcp server.
thanks
mahesh
Hi Mahesh,
Best regards,
Peter
Hi Peter and Reza,
Thanks again for all your help.
regards
mahesh
