Difference between L3 Switch and Multilayer Switch ?
Nabarun Halder
Community Member
5 Replies 5
There is no difference. A Layer3-switch is capable of switching the traffic (L2) and routing the traffic (L3). The routing is done in hardware which is the difference to a traditional router which acts mainly in software.
A Multilayer-Switch can operate both on Layer2 and Layer3. So both terms describe the same thing.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Sandeep Sharma
Hi Nabarun
A L3 switch is a Multilayer switch witch support both L2 and L3 (i.e switching and routing both).
Thanks & Regards
Sandeep
Bilal Nawaz
No difference, they are the same as far as definition goes.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Although L3 switch and multilayer switch are generally considered the same thing now adays (as noted by the other posters), a L3 switch does multilayer switching (MLS), but a multilayer switch might be incapable of L3 routing itself.
A good example of this, a multilayer switch, was the Catalyst 5000 series.  The 5000 could do MLS in conjunction with a standalone router (while it had no on-board L3 routing capability - i.e. so the 5000 without its optional RSM wasn't a single device L3 switch).  It could also do L3 routing (with its optional RSM) while not doing MLS, so then it wasn't acting like a L3 switch.  Only when you configured MLS with its optional RSM did you have it operating as what we today consider a single device L3 switch.
InayathUlla Sharieff
