09-23-2018 09:39 PM - edited 03-08-2019 04:13 PM
i am a bit confused on lacp and pagp. when setting trunking mode is it the same steps on both because i have seen some people who do the interface port command on pagp and they enable trunking through there but on lacp they don't do the interface thing why?
Solved! Go to Solution.
09-24-2018 12:00 AM
Both nearly work same way.
In high level.
PAGP is Cisco Proprietary
LACP Standard ( works with inter-penetrability with other vendors too.)
When you configuring Port-channel / Etherchannel, interface configuration will be override by port-channel/ether channel configuration.
=====️ Preenayamo Vasudevam ️=====
09-23-2018 11:58 PM
09-24-2018 12:00 AM
In high level.
