Difference between trasnceivers
Daniel Boling
Level 3
Level 3
Switch A is: WS-C2960-48TC-S
Switch B is: SG 300-10MP
Neither switch supports a similiar transceiver module.
We are looking at transceiver GLC-SX-MM for Switch A, and MGBSX1 for Switch B
All the Layer-1 information (SX / wavelength, Multi Mode, etc.) I am able to find out about the two transceivers seems to match, so would there be any issue by having these 2 "different" transceivers at either end?
Thank you
Reza Sharifi
I have never used SG 300-10MP, but as long as all your layer-1 and cabling info is correct you should be good to go.
Reza Sharifi
