Bookmark
Subscribe
13588
ISR G2 (1941) and IP SLA command
gilbertojardim
Hi People;
I'm have a new cisco router, and i trying configurate the router with a 2 internet conections, using the ip sla and track commands to backup static route, but i dont could make this config, because the ip sla command not working.
In older configurations, i'm have this command:
ip sla 1
icmp-echo 200.200.1.1 source-interface FastEthernet1
timeout 1000
threshold 40
frequency 3
ip sla schedule 1 life for
ever start-time now
track 123 rtr 1 reachability
delay down 15 up 10
ip route 0.0.0.0 0.0.0.0 200.200.200.200 track 123
ip route 0.0.0.0 0.0.0.0 100.100.100.100 11
but in this router, the help of ip sla command display it:
xxx-xxx(config)# ip sla ?
  key-chain  Use MD5 Authentication for IP SLAs Control Messages
  responder  Enable IP SLAs Responder
xxx-xxx(config)#ip sla responder ?
  auto-register  Setup auto-register to hub
  tcp-connect    Setup tcp-connect responder
  udp-echo       Setup udp-echo responder
  <cr>
someone know how i make this config???
2 Accepted Solutions
Did a bit of digging around and there is something definitely not right. Found this doc -
http://www.cisco.com/en/US/customer/docs/ios/ipsla/configuration/guide/sla_roadmap.html
The IOS links at the top of the doc, you can click on any of them and they take to you to the relevant section within the doc except for 15.1T for which there is no section.
Not sure what has happened to IP SLA. Perhaps someone else can help.
If they can't and you can open TAC cases then there is a new feature for the Network Infrastructure Forums where you can open a case from within a discussion. See this link for more details -
https://supportforums.cisco.com/docs/DOC-13613
Jon
Not if you want to monitor the entire path on each link. I was wondering if performance routing could do it but i haven't really used that.
Jon
24 Replies 24
Jon Marshall
What feature set are you running on the router ?
Jon
IP Base.
I need a special feature set to make this configuration? In the feature navigator this feature is available in IP Base....
Which IOS version are you running ?
I have just checked Feature Navigator with a 1941 running 15.0(1)M and it is not supported in IP Base. It is supported in DATA.
Jon
The IOS version is 15.1(2)T....
I'm search by "Reliable Static Routing Back-up using Object Tracking"....
If i dont have this feature in IP Base, there other method to configure failover of static routes?
Hmmm, there is something a bit funny here. If i search on 15.0(1)M then Feature Navigator list IP SLA operations. If i search under 15.1T there is no mention of IP SLA for any feature set ie. Base or DATA. Not sure what is going on unless Feature Navigator has not been updated properly.
Jon
And without this feature, there other way to configure the failover between two internet connections and static routes? Without the ip sla feature?
Jon
Jon
Just wondering if anyone had a solution for this - I've run into exactly the same problem on an 1841(w/ 3G) running IPBASE 15.1(3)T
Thanks.
aspensystems
We are facing same problem with 1905 with 15.0(1)M2 for ip sla. Somebody said we need to open a TAC case with cisco.
ashok
The IP Base software does not support ip sla feature.
You need the Security or Data License to use this feature.
Gilberto
Thanks, I have already found out the same.
ashok
sir,
whether
cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.0(1)M6, REL
EASE SOFTWARE (fc1)
will support ip sla?
What is your license level? you need the Security license ou data license to use this feature.
