Difference between uplink and downlink ports
weber.hlne
I have to choose a cisco switch model but some ports are named downlink and some other uplink. What it the difference between these ports ?
Thanks.
Example :
Model
Description
Software Image
Cisco IE-2000-4S-TS-G-B
4 10/100BASE-TX SFP module downlink slots
2 Gigabit Ethernet SFP uplink slots
LAN Base
Cisco IE-2000-4S-TS-G-L
LAN Lite
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
An uplink port generally means a port used that connects toward the core of the network.
A downlink port generally mean the converse.
In this particular usage, the switch's downlink ports are dual speed copper ports.  The uplink ports are gig and copper/fiber capable.  The expectation might be users hosts will connect to the downlink ports and the uplink ports will take the aggregate traffic into the rest of the network.
However, you might have one of the "uplink" ports connect to a server (or even both, if there is no larger network).
You're not bound to how you use downlink vs. uplink ports, although sometimes they are hardware different and sometimes they are not.
Thank you for your answer. I was not sure and now I am :-)
