Difference between VLANs and subnets
chandra_rc16
Level 7
Level 7
As of my understanding the difference between VLANs and Subnet is:
VLANs are used to separate the layer2 traffic.
Subnets are for hierarchical arrangement of Layer3 IP addresses, which inturn neccessary for Route summarization.
Chandu
Regards, Chandu
Chandra,
Yes you are perfectly correct.
VLans are used to seperate/segregate the broadcast domain.
(Simple term as you said:  VLANs are used to separate the layer2 traffic.)
More info:
virtual local area network (VLAN) is a logical group of workstations, servers and network devices that appear to be on the same LAN despite their geographical distribution. A VLAN allows a network of computers and users to communicate in a simulated environment as if they exist in a single LAN and are sharing a single broadcast and multicast domain.
Higher-end switches allow the functionality and implementation of VLANs. The purpose of implementing a VLAN is to improve the performance of a network or apply appropriate security features.
subnet
is a logical grouping of connected network devices. Nodes on a subnet tend to be located in close physical proximity to each other on a
LAN
Network designers employ subnets as a way to partition networks into logical segments for greater ease of administration. When subnets are properly implemented, both the performance and security of networks can be improved.
In Internet Protocol (IP) networking, devices on a subnet share contiguous ranges of IP address numbers. A mask (known as the subnet mask or network mask) defines the boundaries of an IP subnet. The correspondence between subnet masks and IP address ranges follows defined mathematical formulas. IT professionals use subnet calculators to map between masks and addresses.
Inayath
***Plz rate if this info is helpfull.
chandra_rc16
Level 7
Level 7
Am i correct. Please help.
Regards, Chandu
Chandra,
More info:
subnet
LAN
Inayath
